Thread: LCD monitor troubles |
Unregistered guest |
| Posted on Tuesday, January 10, 2006 - 02:36 pm: |
I got a Samsung 173V LCD monitor from a friend and have been trying to hook up to my PC that has a CRT monitor. When I run the self test it's fine, but no pic hooked to PC. The web site says that if self test runs, the monitor is good and something else is wrong. I tried all the settings they suggest, but no luck. Can I expect a picture by just hooking up LCD, or do I need a driver installed as well????? Any help is greatly appreciated !! |
rockinjb Unregistered guest |
| Posted on Thursday, January 19, 2006 - 11:52 am: |
I use both crt and lcd monitors and the only computer I had trouble with had an old video card I repalaced it with a newer one and worked. might be worth a try. there are some good ones out there cheap now. |
New member Username: Bobha
Post Number: 3 Registered: Feb-06
| Posted on Monday, February 27, 2006 - 02:42 am: |
Hi It's a CTX S762A LCD Monitor The crazy thing turns off and on repeatedly. It comes on and shows the picture but then turns off and comes back on and shows the picture and turns off again repeatedly. It seems to keep doing this forever. It is getting power and is connected to the computer or it wouldn't show the picture. Any Ideas?
New member Username: Yorkenter
Cape town
Post Number: 1 Registered: Sep-07
| Posted on Saturday, September 15, 2007 - 04:29 pm: |
hi i locked my bush monitor and needto unlock it. can somebody help? i have lost the remote control |
New member Username: Saiyed786
Ahmnedabad,
Gujarat
INDIA
Post Number: 1 Registered: Feb-09
| Posted on Friday, February 13, 2009 - 04:20 am: |
hi it is hcm500pa screeb comes on and shows the picture but then turns off and comes back on and shows the picture and turns off again repeatedly. It seems to keep doing this forever. It is getting power and is connected to the computer or it wouldn't show the picture. Any Ideas? |
