Thread: My speakers don't work |
Unregistered guest |
| Posted on Wednesday, January 04, 2006 - 04:53 pm: |
I plugged my speakers' cables in the right place still, the computer sais :no audio device connected to the computer. can somebody help me? P.s. I don't know much about computers so, don't make it to complicated |
rick in ottawa Unregistered guest |
| Posted on Thursday, January 12, 2006 - 07:50 pm: |
hewlett packard pavilion I unpluged everything moved the computer got everything to work but the @#$@ing speakers. |
New member Username: Seanpenn
Post Number: 2 Registered: Jan-06
| Posted on Thursday, January 19, 2006 - 06:04 am: |
I am assuming you put it in the green audio sockets on te back of you PC. Turned on the speakers, and that the audio drivers are installed correctly. If all these are checked, then your speakers might be broken |
JIM H WILLIAMS Unregistered guest |
| Posted on Thursday, January 26, 2006 - 05:15 pm: |
i have a dimension 3000 i had just got. idon'i know what am doing on a computer it was a gift. now somebody gave me speakers.they dont work. what is wrong? HELP!!!!!!I JUST LOOKED THE SPEAKERS ARE POLK AUDIO. HELP!!!! |
| Posted on Thursday, January 26, 2006 - 05:18 pm: |
Post Number: 5424 Registered: Dec-03
| Posted on Wednesday, February 08, 2006 - 07:05 pm: |
Check if they are powered speakers. |
New member Username: Shazane
Post Number: 1 Registered: Feb-07
| Posted on Tuesday, February 06, 2007 - 03:59 pm: |
my speakers worked fine until I had to do a system recovery, now it wont recognize them anymore |
Platinum Member Username: Project6
Post Number: 12803 Registered: Dec-03
| Posted on Tuesday, February 06, 2007 - 06:25 pm: |
How are your speakers connected to the PC? Make sure that your soundcard is still working. |
Post Number: 2 Registered: Feb-07
| Posted on Tuesday, February 06, 2007 - 06:34 pm: |
nevermind, I fixed it |
