Thread: I uploaded Wav files on Comp with WMA and cant convert them. Help |
Bronze Member Username: Bradrgilman
GALvEStoN ,
Tx
Usa
Post Number: 73 Registered: Nov-05
| Posted on Wednesday, December 14, 2005 - 07:33 pm: |
I uploaded some of my CD's and I think they were wav form and I could only upload them with Windows Media Player and now I cant format the songs to a MP3 format for my ipod and mp3 cd's. How do you upload cds without using windows media? I tried copying them and pasting them but I couldnt without using windows media player. I have 2 comp if you are wondering about the forms. Thanks Brad |
Post Number: 5402 Registered: Dec-03
| Posted on Wednesday, February 08, 2006 - 02:49 am: |
The first problem is the program you are using, windows media player will always convert to WMA. However, Media Player can convert MP3s to WMA format. If you have an iPod just use iTunes to convert the music files to MP3. |
New member Username: Sytrok
Post Number: 4 Registered: Feb-06
| Posted on Tuesday, February 21, 2006 - 02:14 pm: |
If you don't like that option there is a very simple program that you can use. The dbpoweramp music converter. I have been using this for years simply because of how diverse this utility is. It can be loaded and use most, if not all, known audio codecs. You can obtain a copy at http://www.dbpoweramp.com/ Peace; Sytrok |
