Home > Message Board > Computers > Desktops > Archive through June 16, 2006 > Thread: My comp has 40GB, Why does it...
Author Thread: Thread: My comp has 40GB, Why does it say I have 5GB
Username: Bradrgilman
GALvEStoN , Tx
Usa
Post Number: 71
Do any of you know why my comp is saying that I only have 5GB when I know it is a 40GB computer. I went to "my computer" and saw the properties of the C drive and it shows a full memory usage on the C drive and all of the other drives have no memory. So if you know how I can fix it without reforming it or if I have to how do you do it?
Thanks a lot!
Username: Zulkir
U.S.A.
sounds like you partions are messed up or the pins on the back of the hard drive are set wrong.
anthonybib
yea its ur partions or ur using 40GB?!? not many ways to fix partions without reformating unless u wanna run a different system on a partion.
Home > Message Board > Computers > Desktops > Archive through June 16, 2006 > Thread: My comp has 40GB, Why does it... [ « Previous ] [ Next » ]
