Home > Message Board > Computers > Memory > My comp has 40GB, Why does it say I h...
Author Thread: My comp has 40GB, Why does it say I have 5GB.
Username: Bradrgilman
GALvEStoN , Tx
Usa
Post Number: 70
Do any of you know why my comp is saying that I only have 5GB when I know it is a 40GB computer. I went to "my computer" and saw the properties of the C drive and it shows a full memory usage on the C drive and all of the other drives have no memory. So if you know how I can fix it without reforming it or if I have to how do you do it?
Thanks a lot!
Username: Project6
Post Number: 5427
Reload the whole thing. Sounds like a virus.
Username: Hunterjames
Post Number: 15
If your using WinXP, try right clicking on my computer on your desktop --> go to manage --> storage --> disk managemnet
...That should give you all the information you need.
Los Angeles, CA
Post Number: 2461
looks like you need to reformat and reinstall.
Username: Project6
Post Number: 5961
no doubt
Username: Ars88
Post Number: 46
wow
Username: Magfan
Post Number: 230
LONG SHOT::
neighbor of mine had a new HD installed. He loaded all his stuff back on and eventually bought some new antivirus software. It wouldn't load.
I went down and had a look.
The 'technician' who did the work configured it as FAT16, so no matter how large the HD was, it would only see 2gb.
He was at the limit.
Reformat, reload, reconfigure and fixed.
Username: Glasswolf
Wisteria, Lane
Post Number: 12138
how many HDDs do you have? how many partitions?
If C: is the only hard disk and partition, the other drives are optical most likely and will show little to no free space.
Username: 3dges
Compton
Post Number: 49
Try replugging in your HDD
Sometimes a plug comes loose in one of them.
Username: Peeps365
Post Number: 11
difenetly sounds like a virus could jus be a back door trojan som one trying to see what u be up to...... a virus would be there and u won;t be abel to see it it i'll use up most of ur memory by distrubuting it self expanding through ur file but to make along story short to make it simple u should reload the operating system u can get information on how to do this from microsoft.com and they will walk u through it it;s pretty simple job let me know how it works
Username: Peeps365
Post Number: 12
also u not gonna get ur ful space because programs are already on ur machine which will take away some of ur space depends on how much programs u have
Username: Pumpkinman
Ny
download and run hijackthis and send the report in theyll tell you if u have a virus or anything..and tell you how to remove it
Username: Peter_benders
Sandiego, CA
US
no doubt its a virus. try cleaning it however i dont think it will do any good. so format the system. the problem maybe as told by leo
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Computers > Memory > My comp has 40GB, Why does it say I h... [ « Previous ] [ Next » ]
