Home > Message Board > Computers > Accessories > Help
Author Thread: Help
Username: April
I am trying to convert my childrens VHS to DVD and it isnt working. The program that I am using is Studio 9 and it will down load the VHS onto the computer but it wont convert it to DVD. Also does anyone know the differences in the - and + R? I am not sure if I am using the correct one. Please help if you know what I am doing wrong. Thanks in advance
Username: Dtown
Post Number: 10
just my guess,
studio might not be able to produce a DVD-quality product unless you purchase additional upgrades.
in other words, some free programs (ones you get with a USB convertor box) come only with the ability to create an MPEG-1 or MPEG-2 product.
although MPEG-2 is okay for creating a DVD, it is not the best method.
as for the - vs the +, the DVD+R discs are the right way to go. it is newer/faster technology for burning.
is studio recognizing your DVD+RW?
d
Username: Coolwazabi
Nashville, TN
United States
Post Number: 53
ok i HAD studio 9 and it blows... and DVD- is just a different... whats the word... kinda format.. but do - since 90% of all dvd players use - and some use both but almost none use +
dern i got my - & + mixed up.. do + not -... ^_^
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Computers > Accessories > Help [ « Previous ] [ Next » ]
