Thread: My computer display is turned upside down |
Silver Member Username: Bestmankind
Los Angeles,
CA
Post Number: 519 Registered: Oct-05
| Posted on Wednesday, November 16, 2005 - 07:23 pm: |
i have windows 2000 professional. when i turn on my pc, the display looks fine. but when it goes into windows loading screen, the whole display is turned upside down. i can't get it back. what can i do. |
| Posted on Monday, February 13, 2006 - 05:31 am: |
Log in upside down and when you get to the desktop, right click go to your graphic card properties and Rotate 180. Should work. |
Post Number: 5655 Registered: Dec-03
| Posted on Monday, February 13, 2006 - 05:57 am: |
Dang, Chad...what have you been doing to your pc, dude? Go to a blank spot on your desktop Right click go to "Properties" click on "settings" click on "Advanced" go to "graphics driver" click on "graphics properties" click on "rotation" go from there
New member Username: Meggks
Post Number: 1 Registered: Jul-06
| Posted on Wednesday, July 05, 2006 - 03:16 am: |
had this problem...found the answer on a website... Screen Flipped Upside Down PC Errors, Help, and How-to'sDid you walk back to your computer after lunch to find your entire screen is upside down? You have fallen victim to one of the most common office gags. Read this article to find out how to undo this. Holding down CTRL and ALT while pressing the DOWN ARROW flips the screen upside down. To undo it, and flip it back to normal, hold down CTRL and ALT and press the UP ARROW. |
Silver Member Username: Bigsim
Australia
Post Number: 127 Registered: Jan-06
| Posted on Wednesday, July 05, 2006 - 07:51 pm: |
Just tip your monitor upside down. Problem solved  |
New member Username: Tomwysom
Ottawa canada
Post Number: 1 Registered: Aug-06
| Posted on Thursday, August 24, 2006 - 12:39 am: |
same thing happened on my freinds laptop. went to "system restore" and restored the computer to the previous day's settings. it worked thank god or I would have died laughing. |
New member Username: Rabor
Post Number: 1 Registered: Nov-06
| Posted on Tuesday, November 28, 2006 - 07:58 pm: |
<ctrl><alt><up> is the first thing to try. RE: This is a feature in Windows XP Tablet PC Edition. Which makes sense. But it looks like ATI Intel copied the keystroke for the same “feature” in their video card drivers. http://engtech.wordpress.com/2006/08/01/stupid-windows-features-monitor-display- turns-sideways-or-upside-down/ These... <ctrl><alt><left>, <ctrl><alt><right>, <ctrl><alt><down> ...will all have interesting effects too, if you're using the ATI driver. |
