Home > Message Board > Computers > Desktops > Archive through June 16, 2006 > 4 hours to burb 20 min. DVD--why?
Author Thread: 4 hours to burb 20 min. DVD--why?
Username: Jtnt
I'm trying to make my first DVD movie from files captured from my camcorder. I tried a 20 minute test and when I told Nero to burn the DVD it went into a 4-hour trans-coding phase! Is this normal? I want to get to a 92 minute movie eventually, but that'll take almost a full day. Any way around this? It's NeroVision 6 and a 1g AMD processor.
Thanks,
Jack
Username: Samijubal
Post Number: 1820
What type of files are they? It shouldn't have to transcode 20 minutes.
Username: Jtnt
David: Types of files: .avi
Username: Samijubal
Post Number: 1825
I've never worked with AVIs, can't help with that.
Username: Illuminator
Post Number: 2170
The processor speed and RAM might have something to do with it...
Username: Rowlandbrown
Post Number: 12
My advice would be to use WinAVI video converter to change the avi file into a DVD then just burn the DVD. This will take about half an hour (depending on the speed of you DVD writer). The processor speed will make a slight difference but nothing really significant. RAM won’t make much difference in this case.
Username: 420pimp2
Post Number: 7
takes me 1 and a half hours to burn 4.0 gb avi file
Username: Goon
Post Number: 357
burning video like that it a pretty cpu intesive task. i don't knwo all the details, but i would say the amd 1ghz has something to do with it...amd is excelent, i've only used it. but we are far beyond 1ghz cpus.
Home > Message Board > Computers > Desktops > Archive through June 16, 2006 > 4 hours to burb 20 min. DVD--why? [ « Previous ] [ Next » ]
