Thread: Convert S-Video to VGA |
New member Username: Desertratr
Post Number: 1 Registered: Oct-05
| Posted on Wednesday, October 26, 2005 - 12:16 am: |
I need to convert an S-Video output of a laptop to a VGA signal so I can display it on a PC monitor. Can this be done with a conversion cable of some sort? |
TheMediaGuy Unregistered guest |
| Posted on Tuesday, November 29, 2005 - 01:44 am: |
Yes, search google for s-video to vga converter or search froogle.com for s-video converter or visit this site: http://www.consoleplus.co.uk/index.php?cName=vga-boxes-xbox Enjoy! |
New member Username: Molohov
Post Number: 1 Registered: Dec-05
| Posted on Sunday, December 11, 2005 - 12:42 pm: |
I have roughly the same dilemma here. I want to convert a S-Video output to a VGA monitor so I can extend my desktop without having to buy a dual-monitor vid card. However, I have not been able to sucessfully find a CABLE that can do this. Does anyone know of one? |
Post Number: 2 Registered: Dec-05
| Posted on Sunday, December 18, 2005 - 01:03 pm: |
UPDATE: I have recently learned that it is impossible to convert S-Video to VGA, at least in a cable. This is becuase there is less information in a S-Video output (in terms of pins) than a VGA requires. Its like turning 9 pins into 15; it's impossible. Hope this helps. |
boyelectric Unregistered guest |
| Posted on Friday, January 06, 2006 - 03:14 pm: |
You need a box, with a processor of some sort... Here's an example: http://www.buy.com/prod/GrandTec_Video_console_Video_to_VGA_Converter_SVideo_GVC _1000/q/loc/101/10402821.html |
