Thread: Laptop connect to LCD TV, how?? HDMI |
Unregistered guest |
| Posted on Monday, October 17, 2005 - 01:45 am: |
So, my new tv 32" LCD Phillips TV, has HDMI connections and it says that to connect a pc, you must connect the HDMI to the DVI of the PC.. However, I have a laptop and it has VGA like most others. Is there anyway that I can connect the computer to the tv this way? I also tried VGA to component and for some reason the tv is not detecting the signal... Help please. Thanks |
Mikewithlink Unregistered guest |
| Posted on Sunday, November 06, 2005 - 04:45 pm: |
check this out have the same tv and same problem. http://www.ramelectronics.net/html/DVI_ADC-converter.html |
New member Username: Hu_oz
Post Number: 1 Registered: Jul-07
| Posted on Tuesday, July 17, 2007 - 11:15 am: |
Hello I have sony vaio laptop vgnfs415s and it has a s-video output on the side of it. My lcd tv 32" samsung has a s-video input on it and I have been trying for hours to get the computer to show up on the tv screen. I have connected the cables correctly but nothing comes out.help me please. |
Bronze Member Username: Slntdeath
Post Number: 21 Registered: Nov-06
| Posted on Thursday, July 19, 2007 - 08:24 pm: |
Huseyin, There's a set of keys on every laptop to enable TV-Out. You will see a small picture of what looks to be a monitor on one of the Fx keys(Usually F5). If, In your case, The key is F5, Press the "Fn" key + "F5". If that doesn't work, Update the latest Graphics Card drivers from the manufacturers website. |
New member Username: Kenken87
Post Number: 1 Registered: Jul-09
| Posted on Wednesday, July 29, 2009 - 07:33 am: |
My laptop screen condemn already, so i link it with a LCD screen. But after i format my windows, then need to register personal information before enter the windows. At this time, i unable to see anything in my LCD screen, and my laptop screen too due to screen condemn. I also cant use the FN + F5 function since not yet enter windows. NOW i Am stuck in there!!! PLESAE HELP!!! |
