Thread: Help with Lexmark X1150 all in one printer |
Kern Kevin Unregistered guest |
| Posted on Friday, October 07, 2005 - 08:54 pm: |
Well i am having an odd problem with my Lexmark x1100 series printer..First i couldn't get it to come up with print, because something was wrong with the printer spooler, So i got the printer spooler reset and it says it is working perfectly. Now I can't print..Liek i can hit print and all that, but the printer doesn't even make a noise, and so i comes up with a commucation error saying to check the connections.. I checked all the connects which are perfect and still nothign. But the odd thing is that the scanner on it works... If u can post anything that would be of help it would be happy used. Thank You PS It's run thur a USB port |
New member Username: Dracon
Post Number: 1 Registered: Sep-06
| Posted on Sunday, September 24, 2006 - 12:47 pm: |
My bet is on drivers - try to uninstall them, reinstall again and try new onens from producer homepage on web. Cheers. |
New member Username: Nsouthall84
Post Number: 1 Registered: Jun-07
| Posted on Tuesday, June 05, 2007 - 05:40 pm: |
How would I install a lexmark x1150 without the disk? |
Silver Member Username: Stefanom
Vienna,
VA
United States
Post Number: 657 Registered: Apr-06
| Posted on Tuesday, June 05, 2007 - 05:47 pm: |
Download the drivers from their website. |
