Thread: Buying a new HD tomorrow... need advice.. |
New member Username: Martin74c
Post Number: 2 Registered: May-05
| Posted on Sunday, September 25, 2005 - 08:03 pm: |
I'm buying a new HD tomorrow, my system is a P4, motherboard MSI ms-7058 915P... i have been using a Western Digital WD Caviar 160 GB, Serial Ata HD, but i want a new one now, and use the old as a back up. I'd like to buy a similar to that one, but since i am going to spend now, maybe there is something better? I am also not an expert (i just plug the things with lots of courage )... In my mobo there are 4 places to plug S-ATA, i've been reading there is S-ATA 2 Harddisks, would one of those be compatible with my system, and will be a big difference in performance?? so, any suggestions are welcome, anything i should know beforehand? |
Relevant Product Info
New member Username: Rowlandbrown
Post Number: 7 Registered: Sep-05
| Posted on Tuesday, November 15, 2005 - 02:17 am: |
I would defiantly get another SATA drive (SATA 150 if you can). Never buy budget dives unless you enjoy losing your data. I suggest another western digital or a Maxtor drive. As for capacity that is up 2 you. |
