Thread: Floppy disks |
New member Username: Turok6_007
Post Number: 10 Registered: Jul-05
| Posted on Monday, September 12, 2005 - 10:53 pm: |
if im tring to open a file on a floppy disk but it wont open what should i do? |
Gold Member Username: Illuminator
Post Number: 1631 Registered: Apr-05
| Posted on Saturday, September 17, 2005 - 01:30 pm: |
What type of file is it? |
Silver Member Username: G3nocd3
San Jose,
Ca
Post Number: 287 Registered: May-05
| Posted on Saturday, October 01, 2005 - 05:39 pm: |
..... It mite be the wrong format. Back in the good ol Days of floppy, there was ibm format, mac format, and pc format, since Ibm had their own hardware and software at the time, they had their own format. SOmetimes it could be used on windows, sometimes not. I reccommend you check the file type, and also make sure its compatible with windows. If its a mac disk it wont work. Etc etc. Think you got the point. LOl. later. |
