Home > Message Board > Computers > Networking > 16 port hub
Author Thread: 16 port hub
Username: Joshockey
Post Number: 21
hi i bought a 16 port hub from a friend and its hookup is cable is there any way to hook dsl to this hub/router i have a 4 hub/router and it came with the internet service its ok but i figure this is more faster seeing it was used in a business.is there any adapters or such that i can buy for this . any help is apreciated
Username: Rowlandbrown
Post Number: 9
It is not very clear what you want to do but if I read you right you want to use this 16 port hub with your internet router because it will be faster because a business used it? Well firstly "because a business used it" doesn’t make it faster and it is probably the same speed as your hub (10 kb/s?). But still yes it is possible to use it with your internet router using a simple crossover cable. Just plug the one port on the internet router into the one port on the 16 port hub.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Computers > Networking > 16 port hub [ « Previous ] [ Next » ]
