Home > Message Board > Computers > Desktops > Archive through November 19, 2005 > A case Mod I found intresting
Author Thread: A case Mod I found intresting
Username: Insearchofbass
Post Number: 3458
This is a simple idea but does show you one way to make your pc dust free inside and allow cooler air into your case. I also figured it might spark other creative variations for some of you.
http://www.overclockers.com/tips1092/
Username: Bassfreak596
Post Number: 119
if the case mod is for cooling purpose then i have my own mod !
its a gauze piece (medical gauze dressing) taped onto the fan that throws cool air on my prescott.
the one in the front sucks in cool air (gauze on a frame in front of it).
the one below the gauze (aligned with my GPU) and one on the back panel throw warm air out.
i vacuum this filter (gauze piece) once a week or repace it whenever required.
prescott overheats. old habits die hard !
this is my cheap alteranative to expensive cooling solutions.
am plannning to replace the panel with acrylic sheet n using a larger fan with lesser RPM (less noise) with neon lighting in it. but i mite colour the neon with a little darker shade (just enough for a blue hue), i dont like it bright and flashy!
Username: Illuminator
Post Number: 1480
The gauze would work, but wouldn't that limit air-flow as well by quite a large amount as opposed to other materials?
The air filter was interesting, but too bulky/ugly for my preferences (if you want your computer dust free for show-off purposes, that air filter would contrast poorly), though nice idea.
Post Number: 120
nope !!
the gauze is pretty good and does not limit the airflow, unless ofcourse u dont vacuum it once a week or in 10ten !
Post Number: 121
10 days*
Lostman
Thermaltake makes case fants that have a cover with a cleanable filter that does the same thing and is more pleasing to the eye.
Home > Message Board > Computers > Desktops > Archive through November 19, 2005 > A case Mod I found intresting [ « Previous ] [ Next » ]
