Thread: Q? p4 1.7ghz |
Bronze Member Username: Vaio
Post Number: 88 Registered: Dec-04
| Posted on Monday, August 15, 2005 - 10:23 am: |
i have a P4 1.7ghz with an asus p4b-lx motherboard with 512mb memory. but the the memory that its haves it pc133. its not fast i was thinking on geting a new motherboard with pc2100 memory that like 266mhz memory buy i dont know if it will be the same are a little faster. |
Silver Member Username: Bassfreak596
Post Number: 117 Registered: Oct-04
| Posted on Monday, August 15, 2005 - 02:23 pm: |
The performance gain will be noticable. But since you are going to buy a new mother board then why not go for something that is like 400Mhz ? |
Silver Member Username: G3nocd3
San Jose,
Ca
Post Number: 265 Registered: May-05
| Posted on Tuesday, August 30, 2005 - 11:03 pm: |
Lol. Ok, well you knew your rams specs, now i have to ask is do you know your bios. Default is 133-200 mhz on bios, could be anywhere between. Unless you know how to change your bios settings for ram, leave it. I really dont see why people trip so much about ram, it is important, but you could have a 300$ set of corsair ram, and still not have it make any noticable difference, Now if your running lets say a 3500+ 64 athalon yes, now then you would need good ram so it wouldnt bottleneck at the ram, but since you have a slow cpu, may i reccommend you look into an SATA Hard drive, or maybe a faster cpu or vid card. Without those core paryts it will be too slow |
