Thread: Help with audio |
New member Username: Kabasa
Post Number: 7 Registered: Jan-05
| Posted on Friday, August 12, 2005 - 07:30 pm: |
i just installed windows xp on a new hard drive and i cant get audio it says no audio device enabled i have new speakers ive tried to find a driver but its hard to tell what make can someone help please |
Gold Member Username: Illuminator
Post Number: 1446 Registered: Apr-05
| Posted on Saturday, August 13, 2005 - 12:47 am: |
You'll need to update your sound driver. |
Silver Member Username: G3nocd3
San Jose,
Ca
Post Number: 240 Registered: May-05
| Posted on Thursday, August 18, 2005 - 06:47 pm: |
Yup. probably didnt install it to begin with. Winidows update will normally catch the missing driver(s). Try that. its sometimes easier then findin who made your onboard audip chip (sometimes the motherbopard manufacture dosent have driver downloads available.) so windows update is normally easiest fix. |
Silver Member Username: Tafkam
Texas
Post Number: 187 Registered: Apr-04
| Posted on Thursday, September 22, 2005 - 08:59 am: |
Do you have built in sound on the motherboard or a card? I will assume that it is built in to the board.....if so do you have a cd that came with the motherboard? Mine does the same thing, every time I do a clean install of Windows I have to drag out the cd that came with the MB and install the audio drivers. If you have some type of audio card, then hopefully it came with drivers on a cd. If you don't have any disks then as the others have said, try windows update, or try the web site of your motherboard maker or sound card maker, etc. |
