Home > Message Board > Computers > Video Graphics Cards > Windows media player shows blank scre...
Author Thread: Windows media player shows blank screen when displayed on TV
Hi all, I am connecting a laptop (dell inspiron 4000 with an ATI mobility 3 video card) to the TV and everything seems to work great until I open windows media player. When the video is being played I can see the whole screen on the TV but windows media player looks blank. When I look at the laptop it is playing fine. I tried downloading the latest video drivers from Dell but their latest drivers are from 2002. ATI didn't seem to have mobility 3 drivers.
Any ideas?
Username: Joshockey
Post Number: 17
i have a geforce 4 in one of my computers and on my gameing computer i have dual n6600gts in it and there both nvidia and to set the resolution for the tv i beleive you must run i the card in clone mode which allows the card to show the desktop on both the computer and the tv. try running the tv wizard if the card allows you to do that im not real familiar with ati never really like them but the setup should be the same. im not sure if this helps but you can email me and give me the details step by step or post them here cause im sure everyone will respond.
Username: G3nocd3
San Jose, Ca
Post Number: 238
Windows media player has a bug in it. id say 90% of the time you wonot be able to get it to work on externial monitors, tv's etc. Make sure its current. Media player 10 dosent have this problem that much. Also clone screens dont work well with windows media player. Dual view, etc does. As long as its not on 2 screens at once it should play alright. Ive ran into this problem alot, so just be patient. Update your drivers as wel. sometimes this fixes it asap.
ChelleyBee
I had a similar problem and had to enable Theater Mode to resolve it. Here's the related ATI knowledge base article:
https://support.ati.com/ics/support/default.asp?deptID=894
Username: Ayeshaslover
Durham, Nc
Usa
Post Number: 7
hey pyro, with nvidea products u go into advanced display options, click your card's tab and go to full screen video and enable it for your tv
Username: Carta
Media player 10 dosent have this problem that much. Also clone <a href="http://www.nyescortasian.com">NY Asian Escort</a> screens dont work well with windows media player. Dual view, etc does. As long as its not on 2 screens at once it <a href="http://www.nyescortasian.com">NY Escort</a> should play alright. Ive ran into this problem alot, so just be patient. Update your drivers as wel. sometimes this fixes it asap.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Computers > Video Graphics Cards > Windows media player shows blank scre... [ « Previous ] [ Next » ]
