Home > Message Board > Computers > Desktops > Archive through November 19, 2005 > IP adresses
Author Thread: IP adresses
Username: Solarpower
I wasn't sure where to post it so I posted it on the first one I saw. If I had an IP adress how would I find out who's IP adress that was?
Username: Illuminator
Post Number: 934
There really isn't a way.
Username: Arrow224
Post Number: 73
Yes there is. Use a program called Visual Route. It will do it for you.
Username: Bassfreak596
Post Number: 102
ip's generally change unless ofcourse your isp has given you a static ip.
Post Number: 961
Visual Route? That thing cost 50 bucks...just to trace IPs! You'd have to be a fairly dedicated hacker to spend that amount of money on that software.
Post Number: 104
if piracy is not an issue, you get the crack online.
Home > Message Board > Computers > Desktops > Archive through November 19, 2005 > IP adresses [ « Previous ] [ Next » ]
