Thread: Addition of fire-wire port on 965GM2 (MS-6743) |
AlexandraM Unregistered guest |
| Posted on Thursday, June 23, 2005 - 03:17 am: |
Hallo, I suddenly realized, that I need a firewire port to transfer my miniDV-videos from my camcorder. According to the manual of our mainboard (965GM2 (MS-6743)) it does have an onboard 1394 (NECPD72874), although I didn't really check if it is there. The problem is, that the 1394 ports (!) are listed at optional, but there is supposed to be a 1394 pin header on the card to connect this optional port. Did anybody try to add this port here this way (my computerstore here is trying to sell me a PCI-firewire... card instead) Thankful for any help or suggestions |
Bronze Member Username: Spawn_2_extreme
Ontario
Post Number: 11 Registered: Jun-06
| Posted on Tuesday, June 20, 2006 - 06:20 pm: |
if u have an available pci slot, u can get a pci card that supports firewire, my workplace shows a pci slot with 3 firewire ports, juz a generic brand but it does the job. |
Bronze Member Username: Appzalien
Cleveland,
Ohio
US of A
Post Number: 36 Registered: May-06
| Posted on Sunday, June 25, 2006 - 09:46 pm: |
Often external firewire ports are options of the case manufacturer along with usb and audio ports separate from the ones in the back that are directly hooked to the motherboard. If your case has a firewire connection it will also have a wire inside to connect to the motherboards header. If not you will have to add a card. To be a little more clear, I bought an Antec case, it had usb and firewire hookups in the front of the case. Which ever motherboard I put into this case, as long as it has the headers for extra usb and fire wire, I can hookup the cases wires for its upfront usb and firewire manually to the headers on the motherboard. Both the case and the motherboard have instructions to show which pins go where. |
