Thread: Hey Sean |
Silver Member Username: Araknid
BOCA ,
FL
U.S.
Post Number: 699 Registered: Nov-04
| Posted on Wednesday, June 15, 2005 - 09:07 pm: |
I Have 2 comps, ones a crappy labtop That can go online, and the other has a burner but there some issues with it and it wont let me get online. I want to know exactly how I can take stuff from this comp just mostly music, Then send it to the other computer through a dbl sided USB cable so that I can burn it. And check out the post where you were talkin about E-mailin the guy about the sub. |
BOCA ,
FL
U.S.
Post Number: 730 Registered: Nov-04
| Posted on Monday, June 20, 2005 - 04:52 am: |
Anybody know then? |
Gold Member Username: Insearchofbass
Post Number: 2812 Registered: Jun-04
| Posted on Monday, June 20, 2005 - 11:05 pm: |
you can use one of these http://lpt.usbfireinfo.com/Products/HomeNetworkingAndLowCostICS/homenetworkingan dlowcostics.htm or if you have etthernet cards in both pcs you can get a router they are pretty much just as cheap and you will be set if you get more than one pc up at a time with dsl or cable modem ...cable modem being the better choice |
