Home > Message Board > Computers > Notebooks > My laptop lcd screen has gone black!
Author Thread: My laptop lcd screen has gone black!
Username: Qazqazq
i have this medion laptop and suddenly one day the screen goes black. i know its on as i can just make out the words on the logon screen. i tried to go in safe mode, no change, change resoulstion, colour quality (16-32bit) but no change. also tried to rub the screen to bring the pixels back to life again (sounds like magic...) but no change
anyone got any ideas to help? i have warranty aswell.
cb
I just need someone to tell me if a comp with these
Pentium4 3.0 Ghz 533 FSB
512 MB Ram
128 Gig Memory
Intel Integrated Graphics Media Accelerator 900
Will work with half life 2?
I tried doom3 and i play it fine but hf2 is said to be more intense graphic requires so someone tell me if i could play it thanks
Username: Jesusofsuburbia
Sorry, I'm really late with this post. But this happened to my old Toshiba laptop. The screen just went really dark and eventually went black. Well, little did I know, something was rubbing against the darn brightness adjustment thing on the side. That may be your problem. Otherwise, I dunno, sorry.
mike i dont know if you are still there but i have a toshiba satellite and its going through the same thing.. I dont know where this brightnees adjustment thing on the side is.. I am a lil worried thinking that it may be a burnt out lcd.... can you elaborate on your correction method please
Username: Joshockey
Post Number: 18
i had the same problem with a compaq presario found out it was the lcd screen cable i hope that helps.
littlelady
Hi,
I have a Dell latitude laptop, and the same has happened to me. My screen has gone near to black, i can see that it is working because i can just about see the background. I don't know what is wrong and would love some help. Thank you.
Username: Joshockey
Post Number: 24
i had a compaq laptop that did the same thing more than likely it is your lcd cable but try readjusting your monitors color refer to your owners manual on that one.
You might have a burned-out flourescent bulb. Laptops work by transmitting light THROUGH the lcd panel. The light comes from a big ol' flourescent lamp behind the panel.
Can you see stuff on your panel in very bright light?
If so, you may have a dead lamp.
Username: Illuminator
Post Number: 1618
It isn't a bulb per se, but rather an EL panel behind the LCD.
If it was a bulb, you would have uneven lighting.
someone else
ive had the same problem with my very old laptop, its just the backlight inverter, i replaced it and the screen was brighter than ever
lanci3170
i have a gateway solo 3450 and same problem as all of you with backlite probs...found some really great site that gave full directions on how to take it apart myself as to save the $200 or $300 fix it fee, and would have cost me just $18 for the bulb, but like an idiot forgot to save to my faves and have never been able to find it again. These were detailed picture for picture directions. Could use some help here...thanks
me0000112
sometimes if u cool it, it goes away happened wif a digital camera
Username: Sp311sp
I am having that problem with my Toshiba laptop similar to what everyone has been discussing. The screen shows the Toshiba and Intel logo on boot up but when it goes to Windows, it is all dark and I cannot see anything at all except the vague ability to make out my desktop icons.
How can I fix this? It seems to happen intermittenly. Sometimes it happens, sometimes it doesnt. I do not want to spend boatloads to fix this.
Any ideas?
Post Number: 2798
Yes, the inverter is going bad, or, less likely, the lighting panel behind the LCD is going bad. Ultimately, you will need new parts.
Username: Divinemushroom
bought a gateway POS (piece of :#@!) for like 150 bucks. Now I am having the black screen too. Thanks for all the suggestions. I did find a site with a pic by pic process or dismantling and replacing the inverter. wish me luck!
DM
http://www.laptopsolutions.plc.uk/solo_9300_assembly_disassembly.htm
Username: Bigsim
Australia
Post Number: 121
Good luck :-)
Post Number: 3248
Sarah, be aware that when the inverter is bad, you can usually still see things on the screen if you look hard enough, if the screen is absolutely dead black, it might not be the inverter at all.
Thanx Jexx for the pointer! Too often people do jump at the first explanation of the problem they are having because it sounds so similar to others issues.
I can barely see the welcome message and the little av that I have for 'my account', so from the discussion thus far I am fairly certain that it is the inverter in question.
After reading other forums and reviews of gateways as well as talking to my own company tech head I have learned that my black screen is probably a result of my nb getting too hot ALL THE TIME, the heat issue is a result of inadequate cooling aids (the internal fan) and that the fan is unable to do its job because the internal power supply is also inadequate. UGH. Do all gateways suck or just mine? So provided I can find all the parts that I need to upgrade myself at an efficient cost hopefully my pc will be up to par in NO TIME. YAY!
Thanks again for that pointer. Kinda like a dr's second opinion. Make sure you get the right diagnosis before you start the cure.
Sarah
Post Number: 3259
Actually, you have fairly common problems. As far as the overheating goes, it is usually caused by dust collecting in the heat sink-no hot air can escape and it just stays vacant inside the laptop. Hold something in the fan, and spray a can or air into there or something similar. Some laptops make it easy to access the fan/heatsink for cleaning by just unscrewing a panel or other simple method.
Anyway, once you get the inverter out, you can type in any numbers you find on the board itself into Google or even ebay. You should be able to find the inverter board this way, and for a good price too. Expect to pay anywhere from $20-160 for a new board, though on mode average, they cost around $60.
Username: Tonysycongle
Jexx,
I have an A105 Toshiba laptop 1 years old. The LCD screen sometimes blinks then goes black..sometimes the screen look good for 5 hours. I could see the mouse cursor and other desktop icons when the screen went black.
How I know for sure it a light bulb or inverter board?
Thanks,
Username: Techme
MIAMI, FL
Post Number: 103
on back you should have vga port connect monitor to it if it works you have a bad inverter or possibility lcd cable is loose.
Username: Xsharpknivesx
Sydney, NSW
Australia
i have a toshiba laptop. I hibernated it and went away for a couple of hours i opened it back up to turn it back on but it was just back so i held the power button in so it would turn off. I turned it back on and the start up windows logo came on as per usual. THEN it came up with
"the last attemp to restart the system from its previous location failed. Attempt to restart again?
.delete restoration data and proceed to system boot menu
or
.continue with system restart"
so i went with continue because i dont want to delete anything and it just went black again!!! I have been advised to go with my gut and not press delete restorantion does anyone have any ideas on what is wrong or what to do?
Username: Crlutes
Louisville, KY
United States
I just ran into a similar but not exact problem with my brother-in-law's laptop, an eMachine. The screen would go dark, but not black, so if you looked REAL hard you could see the images there in the darkness.
After I decided that it probably was a hardware, rather than a software issue. I guessed some sort of short or cable/switch going bad. So, the next time it went dark, I lowered the lid nearly all the way and, VOILA, the screen was lit completely again. I was able to repeat this over and over, so while we don't know exactly what it is, it seems like it must be a connection of some sort between the screen and the guts of the laptop.
Any suggestions would help. Also, any of you who haven't tried this, it's worth a try because at least you can be sure it's hardware rather than software related. And be better informed when you take it to a shop for maintenance.
Username: Del85
Hi I have a Toshiba laptop and its starts up and flashes the Toshiba logo and then goes blank i assume when its starting up in windows but it has allowed me to access the setup utility with no problems any ideas???
Username: Viller
The best way to see if its a bad power inverter board to the back light or if its the backlight "bulbs" is to shine a flashlight on the screen with the computer running.
If you can now see the text on the LCD then its a "back light" problem, the power inverter or the bulbs.
If you can not see any text its not the inverter or bulb. Try hooking your laptop to a external monitor. If the montior works that means your video card is good and that you more than likly have a failed LCD.
replacing the Inverter and entire LCD is normaly a pretty easy task.
Once you have figured out which item is bad open up the computer remove the part and search EBAY for the model number ON the ITEM not your computer.
"Laptops can have many different types of screens per Model number"
~Good Luck~
Username: Viller
Delisiah
If you can enter setup and the the video remains normal then I would say everything is fine with your hardware.
Sounds like there is an issue with windows locking up and never producing the Starting windows screen.
I would suggest trying to reinstall windows to clear this issue.
Username: Viller
Carl Lutes,
I think your right sounds like a loose connecter to the power inverter for the back light these are normaly located in the bottom of the LCD bezel.
Most laptops will have 4 screws located in the 4 corners of the plastic around the LCD most always located under a small round stickers or under a small rubber circle.
check the connections there if thats not it then you may have to dismantle the base. wich can be a pain for even the most seasoned techs. every laptop comes apart differently.
You can also do a EBAY search for LCD power inverter to see what they look like.
Good luck and remeber to be gental with the lcd if you have to remove it they can brake easly.
Username: Techri
Providence, RI
I too have a gateway 3450 with inverter issues. Can someone point me to a site which has a -how to- there?
Thanks
David
Username: Evan904
Hey, I got the same kind problem, Ive got a acer that my dad gave me its almost 2 years old. One day it flicked blacked them back again. it did that a couple times and now its totally black, I can also see faintly the back group apon start up but each time i turn it on it appears to be getting darker, could someone tell me what is probably wrong with it and the cost of what I need to fix it
Username: Wchan
I have a Toshiba M45-S331 laptop. The LCD display screen intermittently goes black. I can see faintly see an image in the background. I am going to attempt to fix it myself but wanted to know "How to tell if it's the inverter or the light bulb that needs replacing?" I dont want to spend money on the wrong replacement part.
Username: Viller
Post Number: 18
wanyin,
replace the convter 1st, the bulbs are normaly inside the LCD panel its self and very hard to replace with out destorying the screen.
Apperently on that model the inverter is prone to burn up heres a replacment from ebay
http://cgi.ebay.com/Inverter-for-Toshiba-Satellite-M45-S331-15-4-WXGA_W0QQitemZ3 10014228526QQihZ021QQcategoryZ52478QQrdZ1QQssPageNameZWD1VQQtrksidZp1638.m118.l1 247QQcmdZViewItem
make sure the screen size is the same Good luck!
Viller
Username: Ikenfixit
HS, Michigan
CCFL As Well as Inverter failure is common for anything that utilizes Flat panel technology.. Inverters are easy to change and the CCFL or more commonly known as Backlight is generally located in the bottom of the panel itself. (Some are easy to change others are an Issue if you are not versed in this field).. www.moniserv.com has the CCFL's, Inverters can be repaired as generally the Boost coil or Piezo electric X-former is the component that fails. Weve repaired/replaced too many to list and just though I'd give my 2 cents worth. Good luck!
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Computers > Notebooks > My laptop lcd screen has gone black! [ « Previous ] [ Next » ]
