Home > Message Board > Computers > Video Graphics Cards > Can you record HD TV onto your comput...
Author Thread: Can you record HD TV onto your computer harddrive?
UncleRico
If I have a Comcast HD cable box and a video card for my computer that says it supports HD, and it has a DVI output, theoretically, couldn't I record HD onto my hard drive? If so, I would need some sort of device to get the HD signal from the cable box to the computer, where it could record the HD signal onto my harddrive. From there, I could set my card to dual output onto my TV and use the DVI output to send the signal from my comp to my TV. Does anyone know if this is possible? I have heard in other forums that it is, but I have seen no clear explanation of how to accomplish this...If anyone has any ideas, please let me know.
Relevant Product Info
Username: Alienloco666
Sunrise, Florida
Post Number: 55
Well
You need to get a TV Tunner card that will record HD TV
Look at this web site
www.kworld.com.tw
Later
Alien
Username: Appzalien
Cleveland, Ohio
US of A
Post Number: 61
What your probably refering to is the combination of an ATI all in wonder video card with an HD compatible capture card with a cable input.
Username: Illuminator
Post Number: 3652
Guys, that's one old post you've bumped up. But hey, if it helps others, I guess it's cool.
Username: Captain
Post Number: 105
awsome
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Computers > Video Graphics Cards > Can you record HD TV onto your comput... [ « Previous ] [ Next » ]
