Thread: Upgrading processors |
Bronze Member Username: Lazarus2297
Post Number: 22 Registered: Jan-05
| Posted on Friday, April 08, 2005 - 02:26 pm: |
I have a question for those who are more in the know than I am. My current processor is a celeron 2.4Ghz, I am wanting to switch to a 2.4 Pentium 4 with a 533Mhz bus and 1MB cache. Would i need to switch the cooling fan or just replace the processor? |
Bronze Member Username: Arrow224
Post Number: 29 Registered: Mar-05
| Posted on Sunday, April 10, 2005 - 04:16 am: |
You get a cooling fan and heatsink (called a HSF) with the processor. So yes, you would. |
Bronze Member Username: G3nocd3
San Jose,
Ca
Post Number: 33 Registered: May-05
| Posted on Sunday, May 08, 2005 - 12:40 am: |
First off the socket has the be the same. if not it wont fit. Second it has to be compatible with your comp. Third yes replace the fan. DOnt be a cheap #4s. Get a new fan, keep it cool, make it last. End of story. |
Silver Member Username: Sony224422
Deep River,
CT
US
Post Number: 251 Registered: Dec-04
| Posted on Monday, October 31, 2005 - 12:30 am: |
i don't think they are the same socket. Infact im like 99.9 percent sure its not. |
Bronze Member Username: Zulkir
U.S.A.
Post Number: 16 Registered: Dec-05
| Posted on Friday, December 30, 2005 - 05:28 pm: |
celeron and pents are diff socket. you cant upgrade unless the socket of the processer is compatable with the motherboard. |
| Posted on Sunday, January 01, 2006 - 04:21 pm: |
Hey, I have a 2.0ghz xeon processor in my computer now and i want to replace it with a 3.0ghz or 3.2ghz xeon. Is this possible? what would i have to do to do it? |
Bronze Member Username: Gamerdude
Ontario
Post Number: 69 Registered: Apr-06
| Posted on Thursday, June 22, 2006 - 08:39 pm: |
Overclock it |
Bronze Member Username: Appzalien
Cleveland,
Ohio
US of A
Post Number: 32 Registered: May-06
| Posted on Friday, June 23, 2006 - 12:24 am: |
Don't listen to the fools, Celeron and Pentium 4 are the same socket (478) but there are two types of processors Celeron and Celeron D and the Pentiums have different names as well Prescott is one I can't remember the other off hand. On your motherboard between the PCI slots should be the model number of the board, use it to find out which CPU's are compatible with your board. If your Mobo is an Asus, go there and look for the model no.. Or if the board is still for sale you can go to an online dealer and look up its specs. |
