Thread: Mini DV to Computer |
dark1337 Unregistered guest |
| Posted on Friday, March 25, 2005 - 02:12 pm: |
Hi, I have a JVC GR-DVR-300U( I think thats it? ) And I can't transfer videos to the computer. I was wondering, if theres like, a device were you insert the MINI DV tape in, and it trasfers it to your computer. If anyone knows if theres something like this, then please respond. |
Bronze Member Username: Vermiciouskanid
San Antonio,
TX
Post Number: 11 Registered: Oct-04
| Posted on Tuesday, March 29, 2005 - 12:32 am: |
The device you speak of is your camera. Usually those cameras have a fire wire (IEEE 1394) or USB port on the rear or side of the cam protected by a rubber boot or cover. refer to your instruction manual or JVCs web site to find out where exactly it is. I think your cams model is a JVC GR DVL300U |
| Posted on Friday, July 08, 2005 - 12:42 pm: |
The question being asked could have referred to alternate devices other than a camcorder. I'm having a very hard time with camcorder firewire ports. They are failing time and again on more than one computer, in more than one location. It would be nice to have a cheap device to hook up that would just submit to the software controlling it in the computer. If it fails, then replace it. As it is, you have to buy a new camera, or put in a new board that exceeds the cost of the camera in many cases. |
| Posted on Friday, July 08, 2005 - 04:54 pm: |
Hello, I have a Sony DCR-HD40 Mini Dv handy Cam with USB, AV and DV slots; I also have a Sony Computer with all the necessary slots to hook up any one of these for transferring video. I was able to hook up the cam via fire wire prior to my computer crashing due to hackers. After I restored my pc back to factory settings nothing I do can find my camcorder. I am stumped and running out of money buying the mini dv tapes each time I want to use the cam. Any one out there have any advice? KC
