Thread: PLEASE HELP BIG PROBLEM |
Bronze Member Username: Delsole
Post Number: 21 Registered: Feb-05
| Posted on Wednesday, February 23, 2005 - 02:07 pm: |
MY mom just boughtA NEW COMPUTER AND I DOWN LOADED A THING CALLED SYSTEM SUIT AND IT DELETED ALL OF THE SHORTCUTS AND DATA TO EVERY THING AND I CANT REBOOT BECAUSE IT SAYS \ WINDOWS COULD NOT RESTART BECAUSE THE FOLLOWING FILE IS MISSING OR CORRUPT {WINDOWS ROOT}/SYSTEM 32/HAL.DLL PLEASE REINSTALL A COPY OF THE ABOVE FILE |
New member Username: Goon
Post Number: 3 Registered: Feb-05
| Posted on Wednesday, February 23, 2005 - 05:03 pm: |
easy way to fix any problem....just format the hdd and reinstall windows. since it's a new comp...there isn't much on there anyways. try just reinstalling windows before you format. hope this helps. |
Bronze Member Username: Edwarl
Melbourne,
Victoria
Australia.
Post Number: 37 Registered: May-04
| Posted on Wednesday, February 23, 2005 - 05:41 pm: |
And ASAP after that create a boot (Start up) disc or CDROM. |
Post Number: 7 Registered: Feb-05
| Posted on Wednesday, February 23, 2005 - 06:19 pm: |
word |
Post Number: 22 Registered: Feb-05
| Posted on Thursday, February 24, 2005 - 09:05 am: |
ya BUT howie the only problem is i cant reboot it because the file i need to reboot ist is corrupt and i have no disc to reinstall windows xp |
Post Number: 2785 Registered: Dec-03
| Posted on Thursday, February 24, 2005 - 09:53 am: |
try this. Turn off the computer Turn it on...and while it is turning on keep your finger on the F8 key. This will put you in safe mode. Go to programs and into system tools. You should have something that says "system restore". Good luck. |
Post Number: 24 Registered: Feb-05
| Posted on Thursday, February 24, 2005 - 12:04 pm: |
Thanks berny but that dident work either it wont let me restore it i dont know why is there a disk that i can buy that will redown load every thing for me |
Post Number: 25 Registered: Feb-05
| Posted on Thursday, February 24, 2005 - 12:07 pm: |
The computer is a hp pavalon a647c/intel pentium processor /microsoft xp |
Post Number: 2787 Registered: Dec-03
| Posted on Thursday, February 24, 2005 - 05:57 pm: |
How old is the computer? If it is less than a year old, you can still call hp tech support. |
Melbourne,
Victoria
Australia.
Post Number: 38 Registered: May-04
| Posted on Thursday, February 24, 2005 - 06:01 pm: |
The only way is as Bernie says.What actually happens when you hold the F8 key down at the start up? What do you get on the screen ? |
Post Number: 29 Registered: Feb-05
| Posted on Thursday, February 24, 2005 - 10:38 pm: |
When i hold the f8 key a hole bunch of options came up like a couple different safe modes and some different system retores but they wouldent work |
Post Number: 30 Registered: Feb-05
| Posted on Thursday, February 24, 2005 - 10:39 pm: |
the computer is less then a year old it is like 5 months
Post Number: 2789 Registered: Dec-03
| Posted on Friday, February 25, 2005 - 07:25 am: |
You are still under warranty...call hp and have your receipt handy. They should be able to help you out free of charge. |
Post Number: 33 Registered: Feb-05
| Posted on Wednesday, March 02, 2005 - 02:22 pm: |
ok thanks alot to all of you |
Unregistered guest |
| Posted on Tuesday, May 03, 2005 - 07:17 am: |
I HAVE AN HP AS WELL WITH THE SAME PROB..HP HAS A BUILT IN SYSTEM RESTORE WHEN IT'S OPENING PRESS F10 I THINK IF NOT TRY F9 THIS WILL PUT THE PUTER INTO SYSTEM RESTORE AND FOLLOW THE PROMPTS IT WORK FOR ME....GOOD LUCK |
New member Username: Vegetex
Post Number: 5 Registered: Apr-05
| Posted on Tuesday, May 03, 2005 - 03:16 pm: |
what i would do.. if i had that problem is make a disk http://www.bootdisk.com/ get a winNT/XP disk. put that on a nice formatted floppy start ur pc and then let the disk do its stuff and then have the xp CD inserted to install windows XP. if the disk dont start look in the BIOS to see if floppy is bootable. |
