Thread: Intermittant operation of mini USB mouse - any ideas? |
Silver Member Username: Varney
Birmingham England, UK
Post Number: 360 Registered: Sep-04
| Posted on Saturday, February 12, 2005 - 08:45 am: |
I have recently bought a mouse which fits to my USB, instead of PS2, which I always had. My machine has wround 6 USB sockets, 2 being at the front. When plugged into one, the mouse started to suddenly stop working for no reason. Plugging it back in made no difference, until I rebooted. Using the next one down on the front, it worked well for a long time, now suddenly has started behaving the same, only this time, hotplugging in/out fixes the problem for a time, before it starts acting up again. It is a mini mouse which is designed to be used with a laptop and has a very thin cable. It's operation is optical and it has a cable reel. Because the cable is too short to stretch using a full size PC under my bench, I have extended the connection, using a 3 metre USB extension cable. If anyone can see any potential reasons for a USB mouse to behave this way, I would be very grateful for any comments. Thanks in advance, V |
Bronze Member Username: Arrow224
Post Number: 30 Registered: Mar-05
| Posted on Sunday, April 10, 2005 - 04:19 am: |
If you take out the extension cable? That could be the problem. |
Bronze Member Username: Videoguy
Post Number: 50 Registered: Apr-05
| Posted on Sunday, April 10, 2005 - 04:35 pm: |
There might be a faulty wire somewhere, the most likely place is at the point where the cable goes into the mouse. This could explain why it works for a little while and then stops. |
Bronze Member Username: G3nocd3
San Jose,
Ca
Post Number: 54 Registered: May-05
| Posted on Monday, May 09, 2005 - 02:14 am: |
Get a normal mouse with usb. Good mice are microsoft, logitech, razor. |
| Posted on Thursday, August 11, 2005 - 09:40 pm: |
i have the same problem with the optical mouse that came with my hp.... damn thing freezes up all the time.... been doing it for a mouth then about one in ten times i get a msg saying my usb device is malfunctioning or not recoginized |
Silver Member Username: G3nocd3
San Jose,
Ca
Post Number: 228 Registered: May-05
| Posted on Thursday, August 11, 2005 - 09:58 pm: |
Cheap mice do that. Hense "Hewlet Packard". I wouldn t use an extension for mice bro. Your dpi, or in other words the reaction time bewteen your hand and the comp, will be effected by an extension. Either get a mouse with a longer cable or get a good wireless. I have a Logitech mx 1000 lazer wireless. Works great. (I have a logitech mx 510, Microsof optical, microsoft optical trac ball, ) all work fine all have abnormally long cables. COnnections mess signal up, espcially if the cable is bad. lol. So yea. dont be a cheap a$s. go get a decent mouse if u want it to work like a mouse should. sub 20 dollar mice normally arent worth a penny. Id get a logitech or microsoft. or if u wanna game a razor. |
Gold Member Username: Illuminator
Post Number: 1409 Registered: Apr-05
| Posted on Friday, August 12, 2005 - 12:21 am: |
I'm going to get the Razer Diamondback Plasma! Not worth the wait for the +400dpi higer Copperhead to come out and be priced for tons more. |
San Jose,
Ca
Post Number: 229 Registered: May-05
| Posted on Friday, August 12, 2005 - 01:45 am: |
Razor is 1600DPI, Mx1000 is 1000dpi. Razor is corded, mx1000 wireless, razor optical, mx1000 lazer, razor wired and light, mx1000 heavy, It took me about a month to get used to my mouse, I like the mx1000 the most, and when im playin lan matches on cs i use a razor |
Post Number: 1416 Registered: Apr-05
| Posted on Friday, August 12, 2005 - 01:53 am: |
What version of the Razer do you have? |
San Jose,
Ca
Post Number: 230 Registered: May-05
| Posted on Friday, August 12, 2005 - 03:42 am: |
Razer Diamondback Plasma *Limited Edition* 1600 DPI Optical Mouse . its 60$ from xoxide.com. this is a great site. I have a ratpadz gs mouse pad also. I just got my steel pad last week. Great site. |
Post Number: 1426 Registered: Apr-05
| Posted on Friday, August 12, 2005 - 02:14 pm: |
Cool, that's the one I plan on getting. Does it really require the steel pad to work better? |
New member Username: Soundmairman
Post Number: 3 Registered: Mar-07
| Posted on Monday, March 05, 2007 - 11:46 am: |
I agree with the Tim's post. Microsoft, logitech, razor are the best you can find |
