Thread: Any tips on networking ?? |
Silver Member Username: Jdsaenz1
Post Number: 108 Registered: Jun-04
| Posted on Thursday, February 10, 2005 - 01:25 pm: |
I've been able to network 2 computers at home pretty easily; both are running xp. However, at the workplace, I'm using the same router as I am at home, same setup procedure, but the internet connection at work is satellite (vs. a cable/modem connection at home). My first message on both PCs is that there is an ip address conflict; I'm not able to get the networking wizard to show a connection to each pc. Any thoughts or suggestions? Or sites that provide basic info on networking? |
New member Username: Vermiciouskanid
San Antonio,
TX
Post Number: 5 Registered: Oct-04
| Posted on Monday, March 28, 2005 - 08:37 pm: |
couple point 2 remember - make sure DHCP is enabled for both machines - make sure your PCs each have a unique username - make sure your PCs belong to the same workgroup The router should take care of everything else. If you need instruction on any of the configs, let me know. I am lazy an dont wanna type em out if you already know how Web and E-Mail Hosting + free trial |
Unregistered guest |
| Posted on Saturday, July 30, 2005 - 07:34 pm: |
whats the best and cheapest way to network 3 computers |
Silver Member Username: G3nocd3
San Jose,
Ca
Post Number: 242 Registered: May-05
| Posted on Thursday, August 18, 2005 - 06:51 pm: |
router,hub,switch, ETC. Ive seen cheap switches and hubs for like 10 buks. Look around. Tigerdirect.com |
Bronze Member Username: Tasattack
Post Number: 19 Registered: Sep-05
| Posted on Sunday, September 11, 2005 - 03:38 am: |
if its a small network in the workplace under 10pcs and they had statically assigned all your ip/dhcp info that could be the problem; a duplicate ip address. 2 ways to check this on xp systems, start>run> cmd press enter. type ipconfig /all. or right click my network places>properties>right click local area connection>properties scroll to internet protocol tcp/ip highlight it, and press properties. if you see an ip address of 169.x.x.x then windows issued it and there are some issues with the network. |
New member Username: Rowlandbrown
Post Number: 10 Registered: Sep-05
| Posted on Tuesday, November 15, 2005 - 02:42 am: |
Configure all your IP addresses dynamically as opposed to statically and everything should work out fine. The problem probably occurred at work and not at home because the work machines were probably previously on a network. Don’t forget to configure the router with its own IP.
