Thread: IMPORTANT ? on Computer Speakers |
cabledr Unregistered guest |
| Posted on Monday, December 27, 2004 - 12:58 am: |
I have a 2.0 computer speaker system. I am using the Bose Mediamates. They sound really good but I was also looking for something with more bass. I recieved them as a gift so I can return them. Before I do that I was wondering if I can just buy another 2.1 or 3.1 sytem and use both of them at the same time? Or does anyone know of any 4.1 systems that are roomshaking? |
Bronze Member Username: James_the_god
Doncaster,
South Yorkshire
England
Post Number: 24 Registered: Jan-05
| Posted on Thursday, January 13, 2005 - 02:15 pm: |
I can give you a couple of sites which have 4.1 systems. www.mksound.com - you can choose your own speakers to make up you own system here! or www.cambridgesoundworks.com with the more satellite and sub type setup
Bronze Member Username: Touche6784
Post Number: 86 Registered: Nov-04
| Posted on Thursday, January 20, 2005 - 11:45 pm: |
klipsch sells some very nice pc speaker sets. i have one of their older 4.1 systems....very good |
Silver Member Username: Araknid
BOCA ,
FL
U.S.
Post Number: 211 Registered: Nov-04
| Posted on Wednesday, January 26, 2005 - 09:01 am: |
your not gonna get room shaking outta a computer speaker set.... interested in room shaking gotta go custom set up. |
Bronze Member Username: Gamerdude
Ontario
Post Number: 22 Registered: Apr-06
| Posted on Friday, May 05, 2006 - 10:23 pm: |
i got room shacking bass with my computer speakers there only 90watts |
Gold Member Username: Illuminator
Post Number: 2966 Registered: Apr-05
| Posted on Saturday, May 06, 2006 - 01:21 pm: |
TOTAL CONTINUOUS POWER: 80 Watts RMS • Front Speakers: 10 Watts/channel @ 8 ohms @ 10% THD @ 122 - 20000 Hz 2 Channels Loaded • Surround Speakers: 10 Watts/channel @ 8 ohms@ 10% THD @ 101 - 20000 Hz 2 Channels Loaded • Center Speaker: 10 Watts/channel @ 8 ohms @ 10% THD @ 115 - 20000 Hz Single Channel Loaded • Subwoofer: 30 Watts/channel @ 8 ohms @ 10% THD @ 33 - 140 Hz Single Channel Loaded SYSTEM RESPONSE: 40 Hz - 20 kHz (-10 dB) SIGNAL TO NOISE RATIO @ 1 KHZ INPUT: > 75dB DRIVERS (PER SATELLITE): One 3" fullrange driver (front channel) and one 3" full-range dipole driver (surround channel) DIMENSIONS: 3.7" (W) x 3.6" (D) x 7.8" (H) 94 mm (W) x 91 mm (D) x 198 mm (H) CENTER SPEAKER: One 3" full-range driver DIMENSIONS: 6.3" (W) x 4.25" (D) x 3.9" (H) 160 mm (W) x 108 mm (D) x 99 mm (H) SUBWOOFER DRIVER: One 5.25" long-throw woofer DIMENSIONS: 7.4" (W) x 9.2" (D) x 12.5" (H) 188 mm (W) x 234 mm (D) x 317 mm (H) PACKAGING SPECIFICATIONS: DISPLAY CARTON DIMENSIONS: 14.5" (W) x 9.6" (D) x 17.6" (H) 368mm (W) x 243mm (D) x 448mm (H) DISPLAY CARTON WEIGHT: 14 lbs. 6.3 kg Power rating conforms to FTC Amplifier Rule #16 C.F.R. Part 432. • © Yep, all the power goes to the sub. I doubt it really has room shaking bass...have you listened to B&W speakers and possibly one of their subs? |
Ontario
Post Number: 25 Registered: Apr-06
| Posted on Saturday, May 06, 2006 - 02:51 pm: |
I dont have that crapy pair lol http://www.alteclansing.com/product_details_MX5021_OOS.asp And no i havent listed to them i herd they are good sense i live in a APT it dos shack the room its in adn the room beside it but my buddy is gonna borrow them for awile and hes in a house so then will be the real test |
