Thread: Ohm conversion? |
Unregistered guest |
| Posted on Monday, December 13, 2004 - 07:14 pm: |
I have two huge 6 ohm speakers and I want to hook them up to my computer. The computers speakers are 10 ohm so if I hook the 6 ohm speakers up directly nothing happenes. I am wodering what kind of devise I need to make this work. |
Bronze Member Username: Edwarl
Melbourne,
Victoria
Australia.
Post Number: 21 Registered: May-04
| Posted on Wednesday, December 15, 2004 - 07:33 pm: |
The computer speakers probably have an amplifier built in to their "cabinet". To use your 6 ohm speakers you would need an amplifier to feed them from the computer sound card. To take advantage of their size - "huge" - you want a powerful amplifier and it would have to have an output impedance figure of 6 ohms. |
New member Username: James_the_god
Post Number: 8 Registered: Jan-05
| Posted on Monday, January 10, 2005 - 02:47 pm: |
Thats pretty much what i say, ull need a separate amplifier. It depends entirely what output wattage ure speakers are to what amp u get, so check it out in detail otherwise ure 'huge' speakers just wont be worth their while. By the way what speakers are they? I might be able to help you out some more on this one... |
New member Username: Im_roy
Jackson,
Tn
Post Number: 1 Registered: Mar-05
| Posted on Saturday, March 12, 2005 - 12:59 pm: |
aight now i didnt pay attention to science.. how many amps is an 8 ohm speaker? |
Awesome A Unregistered guest |
| Posted on Saturday, March 26, 2005 - 03:28 pm: |
Hate Windows? www.geocities.com/lileclerc20 |
| Posted on Tuesday, February 21, 2006 - 04:28 pm: |
Go here for assistence with ohms |
New member Username: Philb
Post Number: 1 Registered: Jun-06
| Posted on Friday, June 23, 2006 - 08:02 pm: |
You may be able to riase the impedence by using whats called a "sandbar". |
Post Number: 2 Registered: Jun-06
| Posted on Friday, June 23, 2006 - 08:03 pm: |
You may be able to raise the impedence by using whats called a "sandbar". |
Gold Member Username: Illuminator
Post Number: 4020 Registered: Apr-05
| Posted on Monday, August 14, 2006 - 10:41 am: |
Uh, right, Phil. There is no way to change ohm impedance of a speaker without taking the speaker apart and modifying it. You're probably getting no sound because you don't have enough power @ original poster. (As old as that post is)... |
New member Username: Speakerluv
Chatsworth,
Ca
USA BABY!!
Post Number: 2 Registered: Oct-07
| Posted on Monday, August 24, 2009 - 05:10 pm: |
are the speakers amplified? you didn't say... Here is a link to help explain Ohm and impedance http://www.onlyfactorydirect.net/servlet/Page?template=whatis |
