Thread: Panic ! ASUS P4PE (P4PE/L/GD) |
precious Unregistered guest |
| Posted on Tuesday, November 30, 2004 - 02:21 pm: |
Bought a new Serial ATA hard drive, and I didnt think about - what if my mainboard doesnt support any SATA? Does this mainboard have any? :D |
Bronze Member Username: Allic
Post Number: 74 Registered: Jan-05
| Posted on Sunday, March 13, 2005 - 06:18 am: |
Serial ATA is optional on this motherboard. Which model do you have? P4PE-X P4PE-X/SE P4PE-X/TE P4PE2-X
Ringtone Software
Bronze Member Username: Arrow224
Post Number: 31 Registered: Mar-05
| Posted on Sunday, April 10, 2005 - 04:24 am: |
If you do not have SATA, I think you can get SATA->IDE converters. |
New member Username: Joshockey
Post Number: 2 Registered: Jun-05
| Posted on Thursday, June 23, 2005 - 01:24 am: |
got a question i have several computers and was wandering if a pentium 2 motherboard which slot 1 could be used for a pentium 3 slot 1 |
New member Username: Saw_tech_one
Post Number: 5 Registered: Apr-06
| Posted on Friday, April 21, 2006 - 12:42 pm: |
i have a question did any body ever had problems with the machine w2646 2.60 ghz 40.gb intel celeron processor . i have two and the hard drive light just stay on . i just put on a dvdrw/cdrw rom and the computer hard drivd light stay blinking and the the processor fan dose not spin no more . can you help me .is there any tips to fix this and make the processor good so my hard drive can kick back on. i put the dvdrw/cdrw on cable selec thanxs |
New member Username: Aculous
Post Number: 5 Registered: Jun-06
| Posted on Monday, June 05, 2006 - 02:27 pm: |
well you can get a HDD controller card which will allow you to use the SATA drive. But honestly I always end up putting one IDE drive on the system before I can get windows to recognize the sata drive so its kind of a mute point anyway.
