Home > Message Board > Photography > Digital Cameras > Archive through May 22, 2006 > Need portuguese or english user manua...
Author Thread: Need portuguese or english user manual for Canon Powershot A95
Atrito
I bought my A95 on a french E-shop so the user manual comes in french. Its very dificult for me to understand french so i need the user manual in portuguese or english. Can anyone help me out?
Username: Project6
Post Number: 1323
Have you gone to Canon Tech support?
Also interested in the English one... Could you mail me if you get it? Tx
ATRITO: Suponho que sejas portugues. O manual em portugues ainda nao encontrei. Em todo caso podes achar o manual em ingles aqui: www.canoneos.com
Aqui encontras um link DOWNLOAD LIBRARY. Depois inseres o modelo da maquina e tens todos os manuais . Espero ter ajudado. Em troca podes-me enviar um mail a dizer o k achas da maquina porque tambem vou comprar uma. Adeus.
ssskkk
I am also finding this english manual.
just a few clicks, and find and already read the 160-pages manual. see:
http://consumer.usa.canon.com/ir/controller?act=DownloadDetailAct&fcategoryid=32 0&modelid=10468#New%20Window
Thanks for the link. I was looking for the same manual. Inter7 a camera é muito boa, é uma boa escolha na relação qualidade/preço. Eu comprei na prixmania.com
I wonder if the link provided above works only in USA. I am located in Luxembourg and although I get to the page to download the English manual I do not see the manual file and can't downloaded.
Does anyone know of another site to download the PowerShot A95 manual?
Thanks
Roger W
The PowerShot A95 User's Guide is available on Canon's Canadian web site:
http://www.canon.ca/english/index-customersupport.asp?pid=296
in English, French, Spanish, and Chinese.
Hooray for CANADA!
Roger W
Thank you very much for the link to the Canadian web site. I have already downloaded the file. I am sure it will be a great help.
My best regards from Luxembourg!
ck-pt
thanks
better than this just a portuguese manual...
madhura
Thanks Roger, that was helpful, Canon charges £15 pounds for the kit in the U.K.
Oiseau
Thanks Roger.
*I* was looking for a french manual, cause I bought my A95 in a German shop.... ;)
(I could have sent mine to Atrito in exchange to his french manual, I he only read german!)
Thank you Roger, you saved me!
I bought my A95 from a Czech shop and I'm Romanian. I was looking for English, French or even German version.
misa
Thanks Liewil very much for the link to the English manual of A95.
Cheers
Misa
Sabedie
Thank Roger
That was a great help, you do not know how much time you saved us!! We bought our A95 from France with a French manual and needed English. It is exactly the same but we can understand it :-))))
Thanks for this - bought mine from "Pixmania" who sent English packaging & French manuals! Just about to check the CD's...
need an english manual, all I have before me is Italian.
Username: Project6
Post Number: 5409
Go to nikonusa and download a pdf file.
Home > Message Board > Photography > Digital Cameras > Archive through May 22, 2006 > Need portuguese or english user manua... [ « Previous ] [ Next » ]
