Thread: Problem with firewire |
Unregistered guest |
| Posted on Wednesday, September 01, 2004 - 04:54 pm: |
Ok, I baught a firewire pci card off of ebay brand new factory sealed. It didn't come with the drivers at all but according to the store that was selling it, windows should already have the OHCI Texas Instruments IEEE 1394 drivers. Indead, Windows XP does but I'm having a problem. It finds it and even gets the drivers but then it says erro code 10 and that it cannot start the driver. What does this mean? How can I fix this is my real question. |
Post Number: 1292 Registered: Dec-03
| Posted on Wednesday, September 01, 2004 - 05:21 pm: |
try going to the manufacturer's website and see if they have downloads in the support area. |
New member Username: Alphagirl
Colorado Springs,
Colorado
United State...
Post Number: 3 Registered: Sep-04
| Posted on Wednesday, September 01, 2004 - 10:38 pm: |
I don't even know who the manufacturerer is! Do you think it could be on the card? |
Post Number: 1300 Registered: Dec-03
| Posted on Thursday, September 02, 2004 - 07:08 am: |
I was under the impression that it was made by Texas Instruments??? Yes, check the card, it should be printed on there somewhere. |
crazytaxi119 Unregistered guest |
| Posted on Saturday, October 09, 2004 - 07:52 am: |
I am having the same problem as Alpha. I have been on the Texas site and I still am having no luck. Has anyone got anymore suggestions or shall I just bin the the firewire card. |
| Posted on Tuesday, October 19, 2004 - 04:12 pm: |
Still having no luck. Terry Statham has now thrown it in the bin. Cheers |
| Posted on Thursday, December 23, 2004 - 06:15 am: |
Try the belklien website |
