Home > Message Board > Photography > Camcorders > Archive through April 04, 2005 > How to convert raw DV file into Mpeg 2
Author Thread: How to convert raw DV file into Mpeg 2
CC
I was just wondering what software you use to convert a raw DV file into a mpeg 2 file so that I can burn it to a cd and play it in a dvd player?!?!? Thank you!!!!
Username: Peter
ANY LUCK?
Username: Peter
I'm having the same prob, conv. raw DV file into mpeg 2 etc... They say that "a raw DV file converted into a mpeg 2 file is IDENTICAL in quality compared to the orginal DV tape" . Thats hard to believe...
Username: Spade357
DV has higher resolution than MPEG-2. MPEG-2 is use for DVD. MiniDV (DV) is better in quality than DVD (MPEG-2).
To convert (encode) your DV file (.avi) to MPEG-2, you need to use an encoder program. TMPGenc Plus is an excellent program for this.
But which is faster: capture in mpeg2 or capture in DV and then convert to mpeg2?
Cosmin
There are a couple of MPEG encoders that are able to create MPEG-2 out of raw DV. MainConcept MPEG Encoder and Canopus Procoder are two of them.
To the other posters:
NO, it is NOT true that DV has a higher resolution than DVD. Both of them have 720x480 (NTSC) or 720x576 (PAL). The difference is that DV has a higher bitrate. Yet, a _good_ MPEG encoder may produce an output that is visually indistinguishible from the DV source, because MPEG has stronger compression capabilities (I, P and B frames), while DV has only I frames.
And yes, TMPGEnc is capable to recognize DV-AVI, but it is NOT capable to recognize raw DV.
Thanks Cosmin,that was really helpfull...
Do you know how can we get rid of interlaces without loosing quality?
I used Canopus Procoder.
Are you from Romania?
Thank you very much.
Home > Message Board > Photography > Camcorders > Archive through April 04, 2005 > How to convert raw DV file into Mpeg 2 [ « Previous ] [ Next » ]
