Thread: Convert from VHS to mini DV with JVC GR-DVL300 |
Unregistered guest |
| Posted on Wednesday, June 23, 2004 - 10:34 pm: |
Does anyone know how to transfer video from VHS tape to JVC GR-DLV300. I use this camera to do editing on my computer with Adobe Primere and would love to also be able to add my old home movies to my DVD collection. I know that the camera CAN accept input from the computer VIA firewire, but I can not find a way to get it to recieve images from a VCR. I have explored the menu and all I found are the following options: *Sound Mode *12Bit Mode *Syncro *Rec Mode *On Screen *Date / Time *Time Code Any help would be greatly appreaciated! Thanks! smj0724@myway.com |
Silver Member Username: Project6
Post Number: 918 Registered: Dec-03
| Posted on Thursday, June 24, 2004 - 08:24 pm: |
you have to use the analog input of the camcorder. Use it as you would a regular VCR, use your VCR as a source. |
Stephen Juliano Unregistered guest |
| Posted on Friday, June 25, 2004 - 04:16 pm: |
I connect the AV cable to my vcr and to my camera and I do not get anything on the screen, just the default blue. Any suggestions? |
Post Number: 932 Registered: Dec-03
| Posted on Saturday, June 26, 2004 - 10:03 am: |
check your set-up and see if it is ready to accept recordings from an analog source. Remove all other inputs except the av cable from the vcr. Hit the record button on the camcorder and then play the vcr. You should be able to see the pictures from the vcr at this time. |
| Posted on Wednesday, September 01, 2004 - 10:32 am: |
I am wondering about transferring a mini-DV tape to a VHS tape. I live in Japan, but I think all of the settings are the same. I can get the video to play on the tv, but I cannot record successfully on to my VHS tape. I think I am missing a communication link between the tv and vcr. Any suggestions? |
Post Number: 1287 Registered: Dec-03
| Posted on Wednesday, September 01, 2004 - 12:35 pm: |
you have to use the regular Video output of the camcorder and not the DV output. You should have a J-LIP connection on the JVC. |
New member Username: Hurricanec
Post Number: 1 Registered: Oct-04
| Posted on Friday, October 08, 2004 - 11:50 am: |
I'm trying to transfer a mini-DV tape to VHS. As kLo, I can view the tape on my tv but cannot record. I am using the supplied cable from the Canon camcorder and using the AV output of the camcorder into the AV input of the VCR. Any suggestions would be appreciated? |
