Home > Message Board > Photography > Camcorders > Looking for a good Digital camcorder ...
Author Thread: Looking for a good Digital camcorder (new)
Username: Greatful
Post Number: 109
Need some help looking for a camcorder with a 30 gb hard drive,good in low light and with built in image stabilization and easy to transfer to pc for DVD or to DVD recorder can only spend 350.00
thanks,greg
Username: Startlifeendlife
no one seems to have helped you. all i can say is the bigger the chips the camera uses the better low light. im only familar with ccd chips and mini dv cameras, but as far as the new hdd cameras go they prolly use cmos chips and for 350 probabably just one instead of 3. so on the specs page find the size of its chip and try to find the biggest in a name brand camera and you should be okay. (in case you dont know, the chip is what captures the video data (how the camera sees) the bigger the chip the more light it can take in)
hope that ramble helps?
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Photography > Camcorders > Looking for a good Digital camcorder ... [ « Previous ] [ Next » ]
