Thread: Need digital for sports/action shots - help! |
Unregistered guest |
| Posted on Tuesday, June 08, 2004 - 03:19 pm: |
I've tried researching which digital (or digital slr) would be best for shooting my daughter's basketball & volleyball games, and all I am is confused. I love photography, but w/ arthritis in both hands and needing reading glasses, the simpler the better. I've used the new cannon rebel and loved it, but don't know if I need to be switching lenses out if optical zoom will do the job. All I really want is to be able to get really good action shots w/ a digital... recommendations??? Please! |
Silver Member Username: Project6
Post Number: 651 Registered: Dec-03
| Posted on Tuesday, June 08, 2004 - 06:58 pm: |
nikon d70 ...excellent frame rate and you can always get a zoom lens. Doesn't have to be a nikon lens. Sigmas will be fine. Optical zoom is always best...digital zoom pixelates and not a real zoom function. |
| Posted on Friday, June 11, 2004 - 11:45 am: |
Thanks Berny. If optical zoom is best, shouldn't I look for a digital SLR w/out interchangeable lenses? |
Post Number: 684 Registered: Dec-03
| Posted on Friday, June 11, 2004 - 06:48 pm: |
sooze, You might want to look for a digital SLR WITH interchangeable lenses, it just gives you better options. The D70 is a very simple, almost point and shoot camera that is designed for the consumer and the professional photographer. You can select various pre-programmed "scene modes" to minimize the loss of a "kodak" moment. Or you can play with it for the ultimate in artistic control. check out this website http://www.nikonians.org/ |
| Posted on Monday, June 14, 2004 - 09:13 am: |
Thanks much! |
Post Number: 732 Registered: Dec-03
| Posted on Monday, June 14, 2004 - 10:04 am: |
You're welcome! |
| Posted on Saturday, September 25, 2004 - 10:00 am: |
I am starting a small business where I will be taking youth action sports photos, printing and selling at the games. I have decided to go with the D70, but am unsure what additional lenses I am going to need to get the best shots. I don't want to buy more than I need, but when I can't get as close as I want, which lens to I put on to still get the quick action shots? |
Post Number: 1516 Registered: Dec-03
| Posted on Saturday, September 25, 2004 - 02:34 pm: |
One lens you want on your bag will be the Nikon 80-200 AFD 2.8, buy it new as the used ones will cost almost the same as the new one. You can also invest in the newest with Vibration reduction technology, the 70-200mm AFS VR/2.8 here's a good read http://www.kenrockwell.com/nikon/nikkor.htm#rex cheers |
