Thread: What's a good camcorder for around $300? |
New member Username: Lightclouds
Post Number: 8 Registered: Feb-08
| Posted on Wednesday, April 02, 2008 - 03:49 am: |
I am now looking for a good camcorder around $300, I am not sure what kind of camcorder should I get anyway, I want something reliable and easy for use, if it has big capacity that will fine. I will get it from bestbuy, I have found a 5% - 18% off camcorder coupon: http://www.dealstudio.com/searchdeals.php?deal_id=93743&ru=282 Please give me some good suggestions, thanks. |
Platinum Member Username: Project6
Post Number: 15629 Registered: Dec-03
| Posted on Wednesday, April 02, 2008 - 09:56 am: |
Big capacity camcorder? The capacity is dependent on the recording media you use. If you want a camcorder with a hard drive, you may want to increase your budget. Canon and JVC makes good camcorders, pick from those and you will be fine. |
Post Number: 9 Registered: Feb-08
| Posted on Monday, April 07, 2008 - 09:50 am: |
Thanks for your repose, I will have a look at the Canon and JVC, I have heard about them also. |
Post Number: 15661 Registered: Dec-03
| Posted on Tuesday, April 08, 2008 - 09:49 am: |
No worries JVC Everio has a hard drive to record movies. |
