Thread: Archive through October 08, 2006 |
New member Username: Stephiecom
Baton Rouge,
Lousiana
Post Number: 2 Registered: Nov-05
| Posted on Sunday, November 20, 2005 - 10:20 am: |
I just bought a new Nikon D70s from Best Buy. I had to buy it online as they don't carry it in their stores. Have not even had it one week and it has gone nuts. I have a 512 Ultra II Sandisk Compact Flash. Wed. night I went to use it in low light I change the image settings to better quality and that is when everything went wrong. After taking one picture I can't get it to take anymore pictures. Where it shows the number of pictures will show a [r19]. Then after trying to press the shutter button a few times trying to get it to take a picture it will just go blank [ ]. I Then can't get it to do anything. When I turn it off it will then show me the number [556]. When I turn it back on it and press the shutter button it will say [r19] again. I turn it off and the [ ] is blank again. Then back on again and there is nothing in the [ ] and there is no numbers on the top row. HELP did I just get a defective camera? or did I do some thing wrong? I took the memory card out and took off all the pic's I had on it and deleted them from the card. I then put the card back in the camera and formated it. Took one pic and it started all over again. I Took it back to the store and the guy reset the menu and I worked fine for about 30 pics and started all over again. I would play around with it and get some more pic's out of it. |
Post Number: 4290 Registered: Dec-03
| Posted on Sunday, November 20, 2005 - 07:15 pm: |
Sounds like you have defective camera or a return. Was the menu/time/date already set when you received it? Check the number assigned by the camera to your pictures. If you have high numbers, you probably have a returned product. Check the firmware (firmware A and B)and make sure that it is updated to at least 2.0. If it is anything lower than that, you have yourself an old stock camera and you should return it and get new one. If it is brand new, please return it to Best Buy and demand a new one. You have yourself a lemon. Good luck and let us know of any updates. I like to keep track of common problems and resolutions. |
New member Username: Cdmueller
Post Number: 1 Registered: Nov-05
| Posted on Wednesday, November 30, 2005 - 03:24 pm: |
Hello - found this forum when searching for a solution for my D70 problem: Last night (naturally, 2 days before a paid photoshoot I have this Friday, but that's beside the point), after about my 30th pic for the evening, the camera froze up. Upon more investigation, and after seeing the Error (Err) message blink on my LCD, I took of my lens for a peek inside and found the lens had frozen / got stuck in an up position. I made a few attempts at troubleshooting in vain (battery and CF in and out got a few more shots in but the mirror would get stuck again). Turns out there is a service advisory for this. Since I found the problem first on this forum (actually it was in the thread 'D70 - Help!' I thought I'd post the solution, since some have paid for this to get fixed. Go to nikonusa.com and click on Photography. Look for the service advisory button on the right. They'll repair it for free. Hope this helps some people. Cheers, Topher |
Unregistered guest |
| Posted on Tuesday, December 27, 2005 - 05:30 pm: |
Greetings D70S Nikon Users: I bought a D70S at "Best Buy" as a "kit" on September 19, 2005. After about 300 pix, the controls wouldn't work. No readout on CF card as to images remaing on card (San Disk Extreme 1.0 gig). Sent back to Nikon (NY) on December 27, 2005. Anybody else out there? Albert Shank |
| Posted on Thursday, December 29, 2005 - 10:10 pm: |
Hi, I have had my D70 for almost two years, and shot more than 25000 pics with it - almost all with the standard zoom provided. In recent months it occasionally could not be fired even though the autofocus spot was "on". If I shifted to manual focus it was OK and then when returning to autofocus the problem had disappeared. This week I was out cycling and shooting some nice "bovine" landscapes along the way. Then it started with the same locking up problem. Switching to manual focus and back did not help. The LCD panel on top went blank intermittently and the finder became very dark as the lens somehow stopped itself down. The view finder was now impossible to focus even manually. I changed to my spare, fully charged battery but the problems remained. The CF card had retained all the pics up to that point, but the camera is now dead. The manual mentioned resetting with the button on the base, but this did not help. It also talked about how a strong external static charge can stop it from functioning. Indeed, during my cycling trip I had passed under the main high tension power lines feeding Melbourne. However, I believe the camera problem had probably started earlier. I am now waiting for the camera repair shop to re-open after Xmas. Does anybody out there know something about this D70 weirdness? |
Post Number: 4615 Registered: Dec-03
| Posted on Friday, December 30, 2005 - 03:24 am: |
Check Nikon's website for a service advisory. You can get your camera repaired for free if you experience this problem even if the camera is out of warranty. Have you updated your firmware? |
photobug Unregistered guest |
| Posted on Tuesday, February 14, 2006 - 02:00 am: |
Dear all, this really iratates me. My camera creates a wierd grey cast over the image sometimes I use auto color on photoshop but sometimes it makes it so grainy. What can I do is it set wrong. |
Post Number: 5698 Registered: Dec-03
| Posted on Tuesday, February 14, 2006 - 03:41 am: |
Show us a sample and all the EXIF data and we'll see why it does what it does. What is your photographic experience? |
| Posted on Saturday, February 25, 2006 - 10:36 pm: |
My D70 has a flashing memory card access light, control panel dark and playback button will not function properly. What should I doabout this problem? |
Post Number: 6349 Registered: Dec-03
| Posted on Sunday, February 26, 2006 - 01:06 am: |
Try to do a factory reset first. If that does not work go here for free repair. http://www.nikonusa.com/template.php?cat=1 click on service advisory. |
New member Username: Cmsmiami
Post Number: 5 Registered: Oct-05
| Posted on Tuesday, February 28, 2006 - 10:27 am: |
I have a new d70s (since december)It has performed well and all of a sudden the mode dial is impossible to turn and the flash will not pop up. I spoke w Nikon and they said to send it in which I will do as soon as I return home to get the receipt. Any experience in this???I hate it when a repair has to be made on a new item!thanks |
Post Number: 6449 Registered: Dec-03
| Posted on Tuesday, February 28, 2006 - 07:46 pm: |
You're the first I've heard. The repairs usually don't take too long and it is very thorough. |
Bronze Member Username: Crit
Holland,
OH
Post Number: 64 Registered: Apr-05
| Posted on Tuesday, February 28, 2006 - 08:26 pm: |
any chance that something got spilled on your camera??? (soda, or anything that would make things stick when it dries) ----i actually had the problem of my flash not popping up cause i accidentally got a drop of soda in that crack and it caused the flash not to pop...so i had to push the button and manually pull the flash up....the i just simply cleaned off the stickiness and it works great. |
Post Number: 6455 Registered: Dec-03
| Posted on Tuesday, February 28, 2006 - 09:28 pm: |
spilling anything on any electronic equipment is never good. How could you, Christian??? |
Holland,
OH
Post Number: 66 Registered: Apr-05
| Posted on Tuesday, February 28, 2006 - 11:51 pm: |
haha i didnt mean to, i cant remember how it happened, i think i was driving... |
Post Number: 6471 Registered: Dec-03
| Posted on Wednesday, March 01, 2006 - 04:23 am: |
Whoah...back it up there, Christian! You were taking pictures, drinking soda AND driving? Yikes! LOL
Post Number: 6 Registered: Oct-05
| Posted on Wednesday, March 01, 2006 - 07:16 am: |
No, Christian, I did not spill anything that I know about but with the push up and manually opening the flash, it seems to slowly open but I will still send it in because of the mode dial stick will let you know the results if they tell me.thanks for answering. |
Holland,
OH
Post Number: 68 Registered: Apr-05
| Posted on Friday, March 10, 2006 - 05:57 pm: |
hahaha, thats how i do it berny! |
Post Number: 6846 Registered: Dec-03
| Posted on Saturday, March 11, 2006 - 07:18 pm: |
Remind me not be on the same road when you are taking pictures |
New member Username: Cleveland
San francisco,
California
Post Number: 1 Registered: Mar-06
| Posted on Tuesday, March 21, 2006 - 12:09 am: |
Uh...my D70 just sorta died yesterday. Anyone have any suggestions on how to get it restarted? |
Post Number: 7158 Registered: Dec-03
| Posted on Tuesday, March 21, 2006 - 01:04 am: |
Read the Manual under "Troubleshooitng" Then read about "resetting to factory settings" Maybe a new battery. Maybe an approved memory card. Could be anything. Let me guess...you just picked up photography as a hobby? Go to the Nikon website and look at the service advisory. You can send in your camera and Nikon will fix it for free even if it is out of warranty, provided you did not drop it or do anything abusive to your camera. |
New member Username: Robertpeters
| Posted on Thursday, March 23, 2006 - 04:24 pm: |
I have a D-70S. Lately, and on an intermittent basis, when I press the shutter button, there's no image that's captured despite the click of the shutter. The monitor just goes black as if nothing has been captured on the chip. Sometimes it happens 2-3 times consecutively. Usually, I have to turn the camera off and back on again to get it to work properly again. Can anyone offer a reasonable explanation for this? The camera is not even a year old. Thanks. |
Post Number: 7194 Registered: Dec-03
| Posted on Thursday, March 23, 2006 - 10:20 pm: |
What brand memory card are you using? |
Post Number: 2 Registered: Mar-06
| Posted on Saturday, March 25, 2006 - 05:45 am: |
I use Lexar Professional CompactFlash cards - 1GB and 2GB |
Post Number: 7202 Registered: Dec-03
| Posted on Saturday, March 25, 2006 - 07:56 am: |
That is an interesting dilemma. Try doing a factory re-set. |
Post Number: 3 Registered: Mar-06
| Posted on Saturday, March 25, 2006 - 11:22 am: |
Just for clarification purposes, is a "factory re-set" identical to restoring the custom settings to default values as p. 136 of the D70S manual indicates? Thanks. |
Post Number: 7208 Registered: Dec-03
| Posted on Saturday, March 25, 2006 - 05:24 pm: |
Yes |
Post Number: 4 Registered: Mar-06
| Posted on Monday, March 27, 2006 - 08:32 am: |
Ok, thanks. I'll give it a try and see if that corrects the problem. |
Post Number: 7229 Registered: Dec-03
| Posted on Monday, March 27, 2006 - 07:16 pm: |
Keep us posted. |
New member Username: Bonnie
| Posted on Tuesday, March 28, 2006 - 11:02 am: |
i was out on assignment shooting with my Nikon D70s when the control panel screen starting blinking [OFF] and it would not allow me to take a picture. If i play around with it for a while, it will allow me to take a few more, but then it goes back to blinking [OFF]. Does anyone have any advice to give?? |
Post Number: 7258 Registered: Dec-03
| Posted on Tuesday, March 28, 2006 - 04:02 pm: |
More details please. Memory card? Lens? |
New member Username: Canis
Post Number: 1 Registered: Apr-06
| Posted on Tuesday, April 18, 2006 - 01:43 pm: |
I have exacly Bonnie's Problem with my D70. An intermittent fault causes an "off" message to flash in the viewfinder and the LCD panel just where the shutter speed should be. The camera won't to anything. Switching off and on again sems to make no real difference since it usually comes back with the same "off" message. I mainly use raw files in aperture priority mode and sometimes shutter prioiry or manual. It seems to make no difference which mode I'm in. My D70 has an 18-70 lens, firmware a: 1.01 b: 1.02. It has a Lexar 1GB card I called Nikon and they seemed very uninterested. Bonnie's posting is the only mention of a similar thing that I can find, so of course, I'd really appreciate any help on this |
Post Number: 7510 Registered: Dec-03
| Posted on Tuesday, April 18, 2006 - 05:14 pm: |
You really need to update your firmware before you do anything else. There is a reason why these firmwares get updated. |
New member Username: Greensparkles
| Posted on Tuesday, April 18, 2006 - 09:18 pm: |
I wonder if the folks with the "OFF" problem were able to get it solved? My D70s is doing the same thing. It's four months old. So frustrating, and nothing seems to help. |
Post Number: 2 Registered: Apr-06
| Posted on Tuesday, April 18, 2006 - 09:40 pm: |
I hadn't done the firmware upgrade 'cos the fixes mentioned in the upgrade documents didn't really seem to relate to the 'off problem'. Anyway I've upgraded now so hopefully it might make a difference. Howabout you Elsie. Which firmware version is yours using?
Post Number: 7517 Registered: Dec-03
| Posted on Wednesday, April 19, 2006 - 02:51 am: |
Elsie, Your firmware should be up to date if it is only 4 months old. The "Off" problem could be a number of things, but the most common that I know of would be the wrong type of memory cards, such as those not listed in the Nikon manual, dirty contacts on the lenses and the wrong firmware. |
Post Number: 3 Registered: Apr-06
| Posted on Wednesday, April 19, 2006 - 06:06 am: |
Hey there Berny, I've checked my card and it's authorised. My contacts are clean and my firmware is now up to date and (wouldn't you know it) the 'off' message hasn't shown since then. So, it is a permanent fix, or is it just an intermission in the fault? I guess that I won't know unless the fault shows up again. I'll post again if it does. The thing that puzzles me is that it not the 'Err' message that so many people get when the self-diagnostic sytem picks up a problem. It feels like something more specific than that. Someone, somewhere in the design process must definitely have programmed the camera to flash 'off' when particular set of conditions applied but so far the trigger event is just a mystery. I've made another attemtp to interest Nikon in helping me solve this so If they reply with anything useful I'll post again. Thanks - Mike |
New member Username: Upanshu
Post Number: 1 Registered: May-06
| Posted on Wednesday, May 03, 2006 - 07:59 pm: |
Hi, For last few months I am experiencing problem in my D70, it's shooting mode dial is so stiff that I can not rotate it easily, last week I took some 100 pictures, and now I am not even able to move the dial. Does anybody sees this problem, if so, what was the solution? Do I need to send it to Nikon for repair? Thanks, -Upanshu
Post Number: 7847 Registered: Dec-03
| Posted on Wednesday, May 03, 2006 - 09:35 pm: |
Yes. I have never heard of that problem before. Seems like a mechanical problem. |
Post Number: 8 Registered: Apr-06
| Posted on Thursday, May 04, 2006 - 11:50 am: |
Re the 'off' problem. Here's Nikon's response Dear Mike, Depending on data the camera acquires from the lens attached, OFF may be displayed on the control panel and shutter release is not possible. When the lens is removed, this does not occur. To solve the problem, turn the camera off, remove the lens and attach it again. If this phenomenon occurs again, the camera and the lens may not be connected correctly. Please contact your local authorized Nikon representative to have the camera and lens checked. Thank you. Kind Regards, Vladimir Mikulas Nikon Europe Support www.europe-nikon.com/support |
New member Username: Gungho
| Posted on Friday, May 12, 2006 - 07:37 am: |
Anyone knows what happens if you use wrong batteries in the d70? I mean not the CR2 but the thinner version in the battery beholder? Well I did, and now I can't get it to start with a original lion battery, and when I see through the viewfinder there looks like dust or black grime in the lens. Is it destroyed forever or is there a chance to heal it? |
Post Number: 7986 Registered: Dec-03
| Posted on Saturday, May 13, 2006 - 01:56 am: |
First try a factory re-set. If that does not work, send it in. I don't even want to know what you were trying to do...oy! |
Post Number: 2 Registered: May-06
| Posted on Saturday, May 13, 2006 - 03:26 am: |
Bought the wrong batteries from a store. There are two types that fits in the battery beholder. CR2 and the thinner more common type (can't remember the name). |
Post Number: 7989 Registered: Dec-03
| Posted on Saturday, May 13, 2006 - 06:17 pm: |
Just do a re-set and see if you can get it back to factory specs. Good luck, |
New member Username: Noam
| Posted on Wednesday, May 17, 2006 - 05:19 pm: |
hi Is the firmware of d70 and d70s is the same file? |
Post Number: 8033 Registered: Dec-03
| Posted on Wednesday, May 17, 2006 - 10:33 pm: |
Yes |
| Posted on Thursday, May 18, 2006 - 01:01 am: |
hi and sorry for resaking the same q again. can i update the firmware of d70s with this file D70v200 from nikon sith? i just want to be sure that im not killing my kamera. thanks again noam |
Post Number: 8043 Registered: Dec-03
| Posted on Thursday, May 18, 2006 - 11:33 pm: |
check your camera first to determine your firmware version. If you have the D70S, your firmware should still be current and no need for an update. |
Post Number: 3 Registered: May-06
| Posted on Saturday, May 20, 2006 - 07:11 am: |
my v is a 1.00 b 1.00 is it the latest?
Post Number: 8083 Registered: Dec-03
| Posted on Sunday, May 21, 2006 - 02:54 am: |
If you have the D70S...you don't need to update. |
New member Username: Craigp
| Posted on Sunday, May 28, 2006 - 05:02 pm: |
I have owned my D70 for over a year and have experienced the"off" problem. It was driving me crazy for a while, then it seemed to have stopped. I use SanDisk UltraII 512 and 1gb cf cards, and was an early adopter of the firmware update. Now, the problem has re-surfaced. It's hard to know when the camera will work. I read the Nikon response, but it is intriguing, in that I never remove the lens. I have a D200 that is completely faithful. Hmmm.. |
New member Username: 81aoldoak
| Posted on Monday, May 29, 2006 - 12:14 pm: |
I have been using a D70 without trouble since I purchased it in April 2004. Today it will not switch on and the Memory card access lamp flashes. This problem is not addressed in the handbook. |
Post Number: 9 Registered: Apr-06
| Posted on Monday, May 29, 2006 - 01:55 pm: |
You could try a reset Christopher but you've probably got Green Blinking Light of Death a fairly common but not home-fixable problem (google GBLOD for details) - Nikon will fix it for you, even if you are out of warranty. |
Post Number: 10 Registered: Apr-06
| Posted on Monday, May 29, 2006 - 02:11 pm: |
The 'Off' Problem. Yes it is intriguing Craig, Since I posted Nikon's advice about the 'Off' Problem on 4th May, I've come to think that it's not lens related as well. I almost never take my lens off - it's the only one I have - and the problem can occur when my camera is sitting on a tripod, so it's not a movement related problem with the contacts. Mine seems to have gone into remission for a while though - only one or two occurrences in the last couple of months. I guess that if it crops up again regularly I'll send it back to Nikon |
| Posted on Monday, May 29, 2006 - 04:03 pm: |
Hi Mike, The last time the camera failed for no apparent reason, I followed the response from Nikon. With a simple twist of the lens and snapping it back in place, the problem was solved immediately - for now. I have likewise experienced remission. There was a time that I thought the camera would have to go back to Nikon, then it began working faithfully. Now, some months later, it misbehaves again. When there is something important to shoot, I'll be sweating bullets. I have to wonder if the connection problem is due to the way we handle our cameras. So, I'm attempting (hard to change old habits) to be VERY carefully about the way I support the camera, to not put any strain on the lens. If this is the source of a problem with the connection, it doesn't live up to the Nikon reputation for ruggedness. Time will tell. I hear the UPS truck looming on the horizon.... Thanks for the reply.
New member Username: Syvalley
Post Number: 1 Registered: Jun-06
| Posted on Thursday, June 01, 2006 - 10:35 pm: |
Upanshu Singhal, My D70 has the exact same sticky mode dial problem you do. Have you found a solution by any chance? Thx |
New member Username: Becauseyoulove
Bucks county,
Pennsylvania
Usa
Post Number: 5 Registered: Apr-06
| Posted on Friday, June 02, 2006 - 09:51 am: |
My D70s locked up a few days ago. Tried many things. Then noticed a blinking flash icon. Turned flash on/off and wiggled it in the shoe to make sure it had a good connection. Kept trying different things for 15 minutes feeling sick cause I use this thing for events - I can't live with this stuff. Then I took the flash off and put it back on. Amazingly, the camera worked again. Amazing cause everything was turned off when I took the flash off and put it back on! Since I already had checked the connection how should that make a difference? Good to learn about the lens post, above too. Guess in crisis I'll take everything off, put it back on, hit the reset button? |
New member Username: Lindapotter
| Posted on Thursday, June 22, 2006 - 10:29 am: |
The built in speed light on my D70S is not flashing. the assist light works. I did a reset of the camera. Am I doing something wrong? It did work before. |
Post Number: 8301 Registered: Dec-03
| Posted on Thursday, June 22, 2006 - 01:44 pm: |
Lindapotter, Send in your D70 for service. A reset will not help in this matter, sorry.  |
New member Username: Pkn
Palo Alto,
California
Post Number: 1 Registered: Jul-06
| Posted on Monday, July 03, 2006 - 10:47 pm: |
I've got the "OFF" problem is well on my D70s. It's the most frustrating camera issue I've ever had. I'll be somewhere with perfect lighting on the subject and NOTHING I do will convince the camera to fire the shutter. Even going to manual mode doesn't work. I've had the D70s for 9 months and the "Off" issue made it's appearance about 3 months ago. I finally got around to calling Nikon and they had me do the "reset" which we all know doesn't solve the problem. I haven't taken the lens off since I purchased it so I doubt that's an issue. If it is some kind of lens contact issue then I wonder what the value of sending it back to Nikon is. I CAN NOT have a camera that is unreliable. |
Post Number: 8375 Registered: Dec-03
| Posted on Tuesday, July 04, 2006 - 04:39 am: |
If you don't like it, send it back and get something else. No sense in worrying about reliability. |
Bronze Member Username: Canis
Post Number: 11 Registered: Apr-06
| Posted on Tuesday, July 04, 2006 - 08:34 am: |
Hiya Peter You can see Nikon's advice for dealing with the Off problem above - switch it off and re-mount the lens. I've not (touch wood) experienced this problem for a while now - since I gave the lens contacts a thorough rub down and installed the new firmware. Maybe these are worth a try. Also, I've found that Nikon's help and support through their web page is much more efficient than their helpline. Essentialy 'cos you can follow the problem through with the same person. Hope you find a solution Mike |
New member Username: Akwolfsean
Homer,
AK
| Posted on Tuesday, July 04, 2006 - 08:50 pm: |
I've had my D70 for about 9 months now and have loved it. Just yesterday, every time I try to turn it off, it stays on. The only way to get it to turn off is remove the battery. Has anyone else had this problem? |
Post Number: 8396 Registered: Dec-03
| Posted on Wednesday, July 05, 2006 - 06:14 am: |
Try a reset, if that doesn't work, send it in for service. |
New member Username: Varosyps
| Posted on Saturday, July 29, 2006 - 02:23 pm: |
I am unable to use the NIKON D70 monitor as a viewfinder. I find nothing about it in the manual. Can you help me? Paul |
Post Number: 9063 Registered: Dec-03
| Posted on Saturday, July 29, 2006 - 07:37 pm: |
A new Digital SLR user huh? You cannot do that on a D-SLR. What you have there is not one of those disposable digital point and shoot models. You actually have to use the eyepiece to compose and take pictures. |
Silver Member Username: Claudermilk
Post Number: 362 Registered: Sep-04
| Posted on Sunday, July 30, 2006 - 07:12 pm: |
Nah, I'd say a new SLR user. Here's an explanation of why you cannot do this: http://science.howstuffworks.com/camera1.htm --look about halfway down for the diagram. You lose the hold-it-at-arm's-length shooting style and gain much more capability in exchange. |
Post Number: 9102 Registered: Dec-03
| Posted on Sunday, July 30, 2006 - 11:04 pm: |
Agreed... Welcome to the wonderful world of photography, Paul! |
New member Username: Andry1
Post Number: 1 Registered: Aug-06
| Posted on Thursday, August 31, 2006 - 11:48 am: |
hello, i have recently acquired my nikon D70s, and since i have it, i'm having problems in turning my LCD screen on. the first time i've turned it on, it was supposed to appear a menu to choose the language and set the time, but that only appeared after many trys switching between on and off. after that, i still can't see anything on my LCD, and worse, my guide is in french and i can't understand anything can you please help me? best regards Andrey Santa Ana |
Platinum Member Username: Project6
Post Number: 10578 Registered: Dec-03
| Posted on Saturday, September 02, 2006 - 03:50 pm: |
Have you tried pressing the menu button? The LCD is not supposed to be on constantly. |
Post Number: 2 Registered: Aug-06
| Posted on Saturday, September 02, 2006 - 05:35 pm: |
yes berny, i did. matter of fact, after seeing that the LCD wasn't switching on, i tried the menu button , and after that i think i tried every button in the camera. |
Post Number: 10596 Registered: Dec-03
| Posted on Saturday, September 02, 2006 - 11:11 pm: |
Seems like a bum D70. Return and get a different unit. You shouldn't have problems of that nature at all. |
New member Username: Khandan
San Diego,
CA
Post Number: 1 Registered: Sep-06
| Posted on Thursday, September 07, 2006 - 07:07 pm: |
Hello, My D70 is just over a year old & has worked fine so far. Lately I am seeing a small circular black dot near the top right corner on all the pictures when viewed on the computer. I cleaned the lens & the viewfinder. Has any body had this problem?. Thanks in advance. Khandan |
Post Number: 10708 Registered: Dec-03
| Posted on Thursday, September 07, 2006 - 07:13 pm: |
Have you cleaned the sensor? |
San Diego,
CA
Post Number: 2 Registered: Sep-06
| Posted on Thursday, September 07, 2006 - 07:16 pm: |
Sorry for being an ignorant. Where is the sensor? Is it accessible the user? Does the user manual show this? Thanks again. |
Post Number: 10709 Registered: Dec-03
| Posted on Thursday, September 07, 2006 - 10:50 pm: |
Yes, check your manual. You can also put "D70 sensor cleaning" on a search engine and you will get plenty of results. Also try "copperhill method sensor cleaning" |
San Diego,
CA
Post Number: 3 Registered: Sep-06
| Posted on Friday, September 08, 2006 - 09:31 am: |
Thanks for all the information Berny. |
New member Username: Nikonjan
WA
| Posted on Saturday, September 16, 2006 - 02:30 am: |
I just did a search for Nikon D70 problems and here I am. I just sent my camera in to Nikon, my year is almost up. I haven't seen the problem here that I was having. The exposure meter is showing up in all modes, P, A, S and should only be on in manual unless you are trying to adjust the exposure. I would turn both dials trying to get it to zero, sometimes it would go back to normal and then come back. Anyone see this? Thanks! |
New member Username: Hansutz
| Posted on Saturday, September 16, 2006 - 06:42 pm: |
I've had the D70 almost since it was released and have had only minor issues with it until this "green LED of death" problem cropped up. The camera is now with UPS on its way to the Nikon service center. BUT: before realizing there was a service advisory, I'd remove the CF card, reset, and then try to format the card...thinking, of course, that the problem was the CF card and not the camera. Now my CF card is toast. Has anyone seen this problem associated with the death-LED? it's a Lexar 4G pro CF...not cheap, and not cheaply made. and no not even my computer can read it. suggestions? |
Post Number: 10956 Registered: Dec-03
| Posted on Saturday, September 16, 2006 - 08:34 pm: |
Return it to lexar, they've replaced some of my cards for free. |
WA
| Posted on Sunday, September 17, 2006 - 12:41 am: |
I guess the problem I was having may be what you are all calling the "green LED of death" but I never noticed that part of it. But I did happen to go to Nikon web site and see that they were having this exposure problem right after I joined this site. |
| Posted on Sunday, September 17, 2006 - 09:45 pm: |
Berny...thanks for the advice, I'll see what they say. fingers crossed... Jan: The "green LED of death" seems a bit different than what you are seeing. The camera does not properly power up if a card is present, or if it does power up it generates a "CHAR" error (which is related to the memory card), or if it is able to read the card and tries to format it (as in my case) it damages the card. I've not seen the exposure issue, but I don't think I've ever taken tha card out of manual mode so perhaps I've had it all along and I just didn't notice. I'd be interested to hear what you discover. |
| Posted on Sunday, September 17, 2006 - 09:47 pm: |
...of course, I meant that I've never taken *the camera* out of manual mode... |
New member Username: Dante8888
| Posted on Thursday, September 21, 2006 - 12:12 am: |
Hello I'm almost embaressed to ask this but I have to... I just aquired a D70 because I'm finally making the transition from film to digital in the SLR world. However I've come across an issue in which I need some help. When I power up the camera, the rear lcd or monitor as the manual calls it, does not function. The previous owner mentions that all functions were turned off to help save battery life. I've tried many buttons and even the reset button on the bottom of the camera but with no luck. Can someone please offer some advise on how to resolve this? Thank you all for your time and knowledge. D. |
Post Number: 11058 Registered: Dec-03
| Posted on Thursday, September 21, 2006 - 02:35 am: |
Dante, It is not supposed to be on. You are not using a point and shoot camear, it is still a single lens reflex camera. You compose by using the view finder and not the LCD. The lcd turns on just to review the photo you just shot. |
Post Number: 12 Registered: Apr-06
| Posted on Thursday, September 21, 2006 - 12:30 pm: |
Hanz, Have you really never taken the camera out of manual mode? I must admit that I don't exploit a lot of Nikon's functions and use only A, S and M modes but surely, you must be a real puritan. What are you using it for? What sort of pictures do you make? Mike |
| Posted on Thursday, September 21, 2006 - 01:52 pm: |
Hello Berny, Thanks for your response and I really appreciate your knowledge and advise. I understand that you are to compose the picture through the eye piece. I'm having difficutly even accessing the menu feature, with and without a lens attached, to set the camera options. Thanks again! D. |
Post Number: 11065 Registered: Dec-03
| Posted on Thursday, September 21, 2006 - 06:55 pm: |
Yikes...THAT would be a problem. However, the LCD does not automatically turn on when the unit is turned on. You can access the LCD function when you push the "Menu" button and the "Review" button which is on the top left of the LCD screen. If by pushing these buttons, the LCD still does not turn on, you have a defective unit. |
Post Number: 4 Registered: Sep-06
| Posted on Thursday, September 21, 2006 - 09:14 pm: |
Mike: I'm not quite as much a purist as the post would indicate. I'm a big fan of doing whatever makes you most comfortable with the camera, and if you never take it out of the auto mode and still love what you get, all the more power to you. I shoot manual because I tend to bracket the hell out of my shots (which is a principal reason why I switched to digital). I also tend to shoot more landscape and portrait, which means I have the time to set up and compose each shot...if I shot a sporting event, I'd probably rely a lot more on some of the automated functions in the camera. I'm no photo snob...do what you like best and just have fun. |
New member Username: Alainr
| Posted on Monday, October 02, 2006 - 10:50 am: |
Hello, Has anyone had a problems with a flashing grey monitor? Everything was working well then nothing worked. I removed and recharged and re-installed the battery. Now the monitor screen flashes grey even when the power switch is off. |
Post Number: 11197 Registered: Dec-03
| Posted on Monday, October 02, 2006 - 11:06 am: |
Is it when you are reviewing pics or even when there are no files on the memory card? |
WA
| Posted on Friday, October 06, 2006 - 07:59 pm: |
This is the results from Nikon with the problem I was having with the exposure meter showing up in other modes other than manual mode. They replaced the aperture lever and replaced the shutter mechanism, so not a simple fix. |
Post Number: 11260 Registered: Dec-03
| Posted on Saturday, October 07, 2006 - 01:02 am: |
Wow...was it still under warranty? Glad to hear you had it fixed. |
WA
| Posted on Saturday, October 07, 2006 - 12:16 pm: |
Yes, but just barely, it ended Oct.2 and I sent it in in Sept. |
Post Number: 11265 Registered: Dec-03
| Posted on Saturday, October 07, 2006 - 12:25 pm: |
Glad it worked out for you, Jan. What was the turn around time? |
WA
Post Number: 5 Registered: Sep-06
| Posted on Saturday, October 07, 2006 - 02:42 pm: |
It went to Calf. and from send to receive it took about 3 weeks. |
New member Username: Fakerjohn
Post Number: 1 Registered: Oct-06
| Posted on Sunday, October 08, 2006 - 06:07 pm: |
Hi Berny, You have some really impressive coverage on this thread . . . I'm wondering if you can answer a question for me: I have a Nikon D70 with a 128mb card. Just the other day I realized I was only getting 8 shots off the card where I used to get something like 60 or 72. My settings are: Image Quality: Fine (JPEG . . . not RAW/NEF) Image Size: Medium I was thinking maybe the card was just corrupted but wanted to check if you had any other settings you thought I should change or if you could let me know what I should be getting at those settings. One note: I did send this camera back to Nikon twice to have it fixed under a recall against . . . hmm, can't remember . . . Camera just wouldn't do anything. Anyhow, they changed the user interface for the camera and maybe that would have something to do with something. ??? THANKS JOHN |
Post Number: 11275 Registered: Dec-03
| Posted on Sunday, October 08, 2006 - 08:17 pm: |
John, Have you formatted the card? A fine/medium setting will net about 50 images. With the card empty, check the LCD and see if the number of pics left are displayed when using different picture quality settings. |
Post Number: 2 Registered: Oct-06
| Posted on Sunday, October 08, 2006 - 11:15 pm: |
I formatted and I'm back up to 64 shots at fine/medium. Cool. THANKS, BERNY JOHN PS: Do you have any personal lens preferences for this camera beyond the 18-70 that usually ships with it? |
Post Number: 11278 Registered: Dec-03
| Posted on Sunday, October 08, 2006 - 11:54 pm: |
No problem John. Actually, the 18-70 used to stay pretty much on it most of the time. Other than that, the 50mm f/1.8 and the 80-200 f2.8 (if I feel like doing weights) My new favorite however is the 18-200 VR. Not very fast but very versatile. |
