Thread: Camcorder to laptop |
New member Username: Ejdur22
Post Number: 1 Registered: Mar-08
| Posted on Monday, March 10, 2008 - 12:18 pm: |
i have recently purchased a laptop with windows vista ihave a jvc gr-d720ek mini dv camcorder. i use to connect the camera via a firewire cable to my computer no problem but my laptop has no firewire port.i tried connecting via a usb cable but windows movie maker wont recognise it can anyone help please |
Relevant Product Info
Platinum Member Username: Project6
Post Number: 15400 Registered: Dec-03
| Posted on Monday, March 10, 2008 - 08:56 pm: |
That's because you cannot use a USB cable to transfer video from the camcorder to the laptop. You already hit it on the head before with the fire wire. |
Post Number: 2 Registered: Mar-08
| Posted on Tuesday, March 11, 2008 - 03:24 pm: |
thanks but i still dont know how to connect via firewire as my laptop does not have a firewire connection |
Bronze Member Username: Ieee488
Post Number: 69 Registered: Dec-07
| Posted on Tuesday, March 11, 2008 - 04:12 pm: |
you can't connect to what doesn't exist. Buy a PCMCIA Firewire card. |
Post Number: 15418 Registered: Dec-03
| Posted on Tuesday, March 11, 2008 - 07:47 pm: |
^^^there's your answer. You may want to invest in a firewire card if you are going to do a lot of video editing. You also need to increase your RAM to 2 gigs, minimum. A laptop is not conducive to video editing. |
