Home > Message Board > Photography > Camcorders > Help w/ file size
Author Thread: Help w/ file size
Username: Terrapin
Any help (if possible) would be appreciated. I'm still getting familiar w/ transferring from my camcorder to my pc w/ the Image Mixer 1.5. I have a few short 'movies' on there now (each about 10-30 seconds). I wanted to send them as an email attachment, but the file size is always way too large. Is there anything that can be done? Even a 2 or 3 second clip is too big. Thanks a lot for any input!
Relevant Product Info
Username: Project6
Post Number: 15083
If you have really large files such as movies...you need to compress it to a more manageable file. You can zip it or put it in a different format. You can't just put it in an e-mail attachment. You will also need an FTP (File Transfer Protocol). You can put that in a search engine and you will get plenty of hits.
Username: Ieee488
Post Number: 48
convert files to mpeg4 format
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Photography > Camcorders > Help w/ file size [ « Previous ] [ Next » ]
