Home > Message Board > Photography > Camcorders > JVC GZ-HD3 DVD format change
Author Thread: JVC GZ-HD3 DVD format change
Username: Justinh
Anyone know how to do this?
I own one of this cameras, bought from the US, but it records and outputs in NTSC and I would like to change it to PAL. Can that be done? Does anyone know of any gizmo for doing that?
Relevant Product Info
Username: Ieee488
Post Number: 35
Some DVD players can play both PAL and NTSC discs. I have a Cyberhome that was sold here in USA. It has a built-in PAL to NTSC converter so I am able to play a PAL disc.
Username: Justinh
Hello. Thanks for that. It is not just the playing of DVD's that is the issue. I can change the file to PAL when I am producing the video. The issue is really the camera.
Username: Ieee488
Post Number: 36
You get a DVD that is NTSC from your camcorder.
Play that DVD in your DVD player.
What more is there to do?
Username: Justinh
Hello. Well very many DVD players in the UK will not play NTSC. I was wondering how I can alter the camera to produce PAL output.
Username: Ieee488
Post Number: 38
You can't alter the camcorder.
Your option is to software to process the files from the camcorder. Google it.
Username: Justinh
I was just wondering if it were possible. I am aware that I can change the thing with software.
Justin
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Photography > Camcorders > JVC GZ-HD3 DVD format change [ « Previous ] [ Next » ]
