Thread: Cybershot DSC-T70 |
New member Username: Lalipa
DohaQatar,
Qatar
Qatar
Post Number: 1 Registered: Jan-08
| Posted on Friday, January 18, 2008 - 04:23 pm: |
I purchased DSC-T70 two months ago, it went perfectly till date, few days back once it got dropped at 4ft height , it worked well even after dropping. Now I observed when I slide down the lens cover/turnon power, it turns on and then after a blink of the scene, turns off ?? I am not able to shoot picture or movies. However I am able to view/download the pictures I have taken. I tried replacing the stick but failed. Can any one help the remedy or why it happens ! Is it a firmware/hardware problem. Normally while uploading the stuff I used to select all, cut and paste it in my computer folder ! Is there something like any hidden program file got cut also ! |
Platinum Member Username: Project6
Post Number: 14361 Registered: Dec-03
| Posted on Friday, January 18, 2008 - 09:18 pm: |
I doubt that it is a firmware or hardware problem. It could be the 4 foot drop. |
