Thread: Nikon d80 not working |
New member Username: Wildlens
Post Number: 1 Registered: Oct-07
| Posted on Monday, October 01, 2007 - 02:45 pm: |
hi my d80 shows full battery ; autofocus works counter shows ( ) blank, every other setting can be changed except the back panel near the lcd where i can only change the af point with the rocker switch the problem is that i cannot see pictures already on the card or shoot new ones, also the camera cannot be turned off once it is turned on ; i tried the reset button but still the problem persists, is there anything else i can try out. thanks for your suggestions James23p and dm1dave i have already tried the hard reset ,taking off the battery for a few hours had some impact on the functioning i can now turn it off and shutter release button works but still not able to save pictures or access them on any of my 3 cards kingston,transcend and umax none of them is locked and have been using them for the last 6 months. the problem started when one of my friend accidently removed the battery while the cam was on. thought about reinstalling the firmware but the problem is i cannot access the card even when i connect it to the pc the problem occurs with all the cards, the green light never blinks. |
New member Username: Tensamten
Post Number: 1 Registered: Feb-08
| Posted on Thursday, February 28, 2008 - 01:21 am: |
Where you able to find a solution for this problem? |
Platinum Member Username: Project6
Post Number: 15287 Registered: Dec-03
| Posted on Saturday, March 01, 2008 - 10:27 am: |
This is usually because of memory card problems. Use memory cards that are recommended by Nikon and not some off-brand cards. |
