Home > Message Board > Photography > Camcorders > Archive through October 21, 2007 > Sony handy cam question
Author Thread: Sony handy cam question
Username: Acoupleinlove
we have a sony handy cam dcr tvr 520 camcorder and we want to use it as a pc webcam, can this be done and if it can be done what is needed to do it?
Username: Tapeman
New York City in-HD, NY
Post Number: 1284
You mean dcr trv520
Yes you can
You should install software that it came with
Will work great with windows XP and USB connection
If you don't have a USB or firewire it won't work
You can also choose to buy a USB web cam off e-bay at about $15 instead of easly damage your camcorder
yes, thank you so much for responding but i still can't seem to figure out how to make it work. The cam does'nt have a usb hook up but it does have a firewire. Will it still stream video?
Username: Galelee
Shanghai
P.R.China
my fuji s602,which older in today's view,can work as PC Cam if you select it from setup menus,so check the menus careful, you may make it work, good luck
Home > Message Board > Photography > Camcorders > Archive through October 21, 2007 > Sony handy cam question [ « Previous ] [ Next » ]
