Home > Message Board > Photography > Digital Cameras > NIKON D70 picture recongnition
Author Thread: NIKON D70 picture recongnition
Username: Leighowens
Philadelphia, PA
United States
I just got my nikon d70 and i've taken a load of pictures. When I connect it to my computer it takes me through the normal prompts but when it's time to view the pictures my computer says there are no pictures available. Please Help me!!!
Relevant Product Info
Username: Project6
Post Number: 14075
Do you have a memory card reader? It would be easier. Have you installed the NikonView program?
Get out the manual and check the setting on your camera's menu, make sure that the transfer is set up properly. I don't have the manual with me right now so I can't be more specific.
Philadelphia, PA
United States
Actually I figured it out. When I got the camera the picture quality was automatically set to RAW and I took all my pictures in that format. Windows did not recognize this format therefore it was as if there were no pictures on the memory card. What I ended up having to do was to put them all into adobe photoshop lightroom and then export them all to adobe elements in the jpeg format. This solved the problem. Thanks a lot for your response.
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Photography > Digital Cameras > NIKON D70 picture recongnition [ « Previous ] [ Next » ]
