Thread: Capute Mini DV... Black Screen. Help. |
New member Username: Slubberbub
Post Number: 1 Registered: May-07
| Posted on Wednesday, May 23, 2007 - 09:21 pm: |
I have a JVC mini dv camcorder. I also just got a firwire cable. I plug in my cam, turn it to playback, and start up PowerDirector. It has a DV capture feature. The preview window is blank, but I know that my computer recognizes the camera because I can use PowerDirector to make it play, rewind, ect (this i can see on the LCD of the camera). But when I try to record it tells me, "You cannot use the capture function because the iLINK mode on the HDV machine is not identical to the recorded format on the tape. Please change the iLINK mode and try again." I have also tried using Windows Movie Maker, and several other programs. All of them come back with errors and no video. Do I need some kind of drivers for it to record correctly or what? Any help is greatly appreciated. |
New member Username: Asia04
Post Number: 2 Registered: Apr-08
| Posted on Monday, April 28, 2008 - 05:51 am: |
Hi I have the same problem. Can't find the solution. Did you have any luck with capturing? Any help - please... |
Platinum Member Username: Project6
Post Number: 15849 Registered: Dec-03
| Posted on Monday, April 28, 2008 - 10:01 am: |
How much RAM are you running? What is your Operating System? |
Post Number: 3 Registered: Apr-08
| Posted on Monday, April 28, 2008 - 12:21 pm: |
Hi My operating System - Microsoft Windows XP Professional, Version 2002, Service Pack 2 Dell with 1.60GHz, 896MB of RAM, after startup my PF usage is 685MB (if that has anything to do with the performance of my PC) |
Bronze Member Username: Ieee488
Post Number: 91 Registered: Dec-07
| Posted on Monday, April 28, 2008 - 12:30 pm: |
http://www.microsoft.com/downloads/details.aspx?FamilyID=CA0F2007-18B5-4112-8BD6 -8BF4BD3130B9&displaylang=en |
Post Number: 4 Registered: Apr-08
| Posted on Tuesday, April 29, 2008 - 06:13 am: |
Hi there I have installed the update suggested, but still no luck :-( On Power Director I still get the message:” You cannot use the capture function because the iLINK mode on the HDV machine is not identical to the recorded format on the tape. Please change the iLINK mode and try again." , and on Windows Movie Maker - "The video was not captured correctly. Verify that your video camera and capture device are configured properly". The camcorder I'm using is JVC miniDV Digital Video Camera GR-DVP3E - there are no setting for recording other than Long play LP or SP standard play. What do I do wrong??? |
Post Number: 92 Registered: Dec-07
| Posted on Tuesday, April 29, 2008 - 07:08 am: |
Put a brand new tape into the camcorder. Capture some video. And try the video capture again. Try looking around JVC's website for anything about this problem. |
