Thread: Can someone help me plz... |
New member Username: Lucy357
Post Number: 1 Registered: May-07
| Posted on Monday, May 21, 2007 - 12:09 pm: |
i have a sharp 8mm and i wanted to transfer that to the computer using a canon mini dv 16mm that i just bought. i also bought a firewire port because i heard it was faster than usb. so now i just wanted to know exactly how to do this since i think i got everything i need. thanks in advance. |
Platinum Member Username: Project6
Post Number: 14050 Registered: Dec-03
| Posted on Monday, May 21, 2007 - 04:54 pm: |
What video editing program are you using? You need to get decent software (read, paid for) to get respectable results. What is your OS? You need a minimum of XP for ease of use. |
Post Number: 2 Registered: May-07
| Posted on Monday, May 21, 2007 - 05:54 pm: |
Im using windows movie maker. Im not sure what OS means? And I do have windows XP. |
Post Number: 14051 Registered: Dec-03
| Posted on Monday, May 21, 2007 - 08:26 pm: |
You can try the Windows Moviemaker. Now you need a firewire cable to connect your camcorder to the PC. |
Post Number: 3 Registered: May-07
| Posted on Monday, May 21, 2007 - 09:08 pm: |
I did try to plug in the firewire cable to my camcorder but my computer doesnt show that it is connected. I was thinking of using powerproducer 2 gold instead of windows moviemaker. |
