Home > Message Board > Photography > Photographic Accessories > JVC GY-HD100 battery adapter
Author Thread: JVC GY-HD100 battery adapter
Username: Sunpowcn
Zhuhai, Guangdong
China
Input: 11-17V DC
Adapter out: 7.2 DC 20W
Power light out: 14V DC 50W
*For fitting mount adapter onto your JVC GY-HD100/101, is in the same way as a JVC 428 battery mounting directly to camcorder mount
plate. When a broadcast series 14.8V li-ion battery connect to the mount adapter, it makes broadcast high capacity li-ion battery and JVC GY-D100, GY-HD101 camcorder are in integrated.
*The mount adapter will convert the power from 14.8V to 7.2V, and built-in over current and over voltage protection circuits.
*Power tap connector built-in with 14.8V output on mount adapter that can power camera light and other external device at 14.8V directly
*Utilizing the two round screw holes on the edge of mount adapter, an external brackets of a wireless receiver or a hard disk recorder can be connected with the device.
http://www.alelectronics.com/mount.htm
http://www.alelectronics.com/picture/CVP100.jpg
Username: Project6
Post Number: 13784
Thanks for the SPAM you assbucket!
Username: Project6
Post Number: 14824
woot
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Photography > Photographic Accessories > JVC GY-HD100 battery adapter [ « Previous ] [ Next » ]
