Home > Message Board > Photography > Digital Cameras > Telextender vs. Cropping with DSLR
Author Thread: Telextender vs. Cropping with DSLR
Username: Jackkessler
Post Number: 22
I want to take tripod pictures of small remote objects such as birds with a 300mm prime lens. Would the picture be degraded less by adding a 2x telextender or by cropping and magnifying the middle quarter of the picture?
Relevant Product Info
Username: Claudermilk
CA
Post Number: 457
Do you have the TC available? If so, why not perform an experiment & try both methods? From the examples I've seen & comments I've read, a 300mm prime (at least Canon's) is supposed to be able to handle a 2x TC pretty well.
I would not suggest using TCs with zoom lenses as the results are less than optimal.
Username: Project6
Post Number: 13624
Cropping and magnifying usually results in more degradation than dealing with the limitations of an extender.
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Photography > Digital Cameras > Telextender vs. Cropping with DSLR [ « Previous ] [ Next » ]
